Carl83911's Avatar
Magnecore Order.
Hello,
I will be ordering a set of Magnecore ignition wire set for my sc. I have a couple of questions.
1. does the set come with the wire spacers/holders?
2. Are the connectors 90 degrees or straight.
I'm posting this 'cause the order office is closed for the evening but I would like to order tonight.
thanks in advance.
Carl
Carl,
Old 04-05-2012, 06:46 PM
muck-raker
kidrock's Avatar
Magnecores DO NOT come with spacers/holders. You can use your old Beru stuff, clean 'em up real good and stick 'em on your new wires.
Magnecores go straight into the plugs, and have 90 degree connectors onto your distributor.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 04-05-2012, 07:00 PM
Chief Head Scratcher
kerthunk's Avatar
1. No wire holders.
2. The SC set has 90 deg at the plugs and straight at the distributor.
John Morris
'79 911SC
Old 04-05-2012, 07:10 PM
Carl83911's Avatar
Thank you.
Carl,
Old 04-05-2012, 09:30 PM
Diss Member
Quicksilver's Avatar
Reusing the stock wire spreaders depends on the size of the wires you get. The larger diameter wires require that the wire holders be modified. I used a drill to open up the holders so the 10mm wires would fit.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 04-05-2012, 10:37 PM
