Greetings,
The ignition system went in my 72s.......I would like to know how long it would take a spec to replace. This is the switch only..same key. This is the first time it has been replaced since new with a later model one.......The spec I am using is claiming it will take 6 hours to replace.I can rebuild a complete motor in 6 hours.?? The second problem I am having is that my right hand turn signals are not working,,,Any suggestions.left hand signals are working fine. |
It took me a full day. Remove seat. Remove steering wheel. drop a/c etc.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
ROW '78 911 Targa
Probably could be done a little faster but not by much. I don't mean to sound rude but if you can rebuild a Porsche engine in 6 hours why do you need anyone to work on replacing the switch?
