-   -   Switch to Kendall oil appears to have solved my long-term chain rattle issue! (http://forums.pelicanparts.com/porsche-911-technical-forum/662927-switch-kendall-oil-appears-have-solved-my-long-term-chain-rattle-issue.html)
mthomas58 03-04-2012 02:10 PM
In connection with a recent breakdown in Asheville I met Scott Spence, long term Porsche mechanic and engine rebuilder in CA with Bruce Anderson who now owns German Motor Werks in Asheville. We spoke about my long term chain rattle that I've had with my orig engine and replacement engine (installed 2 years ago) Rattle occurs consistently at high engine temps and low gear low RPM conditions.
He said perhaps it is the oil I'm using and suggested Kendall. When working on race teams in the old days he stated that they would ship Kendall overseas for races. He changed the oil and adjusted the valves two weeks ago and so far no chain rattle! I think the Valvoline VR1 Racing oil I've been using gets too thin at high temps and the hydraulic tensionsers don't work properly. I've had this chronic problem for several years with two different engines so this change to Kendall and the elimination of chain rattle is huge for me. Just wanted to share. I'm surprised that a simple change in oil could have such a profound impact on tensioner performance. (now using Kendall 20W 50 dino vs Valvoline VR1 20W 50 dino racing oil)
brads911sc 03-04-2012 03:02 PM
been using GT1 for years. good stuff...
RSTarga 03-04-2012 03:08 PM
The real Kendall (original),is now Brad Penn.
Reiver 03-04-2012 05:14 PM
The stuff he shipped overseas in 'the old days' is now B Penn as they bought the Kendall platform,,,,Kendall is now reg oil not prop up to snuff for flat tap motors.
Jerome74911S 03-04-2012 05:24 PM
Kendall GT-1 20W50 sold today is advertised as being appropriate for high performance flat-tappet camshaft engines. It states that it has high ZDDP (I don't have the numbers in front of me).
Anyway, all of this can be found on the gargantuan oil thread here on PP.
Canada Kev 03-04-2012 06:25 PM
Maybe the Kendall GT1 is the same as Brad Penn, but with a different sticker on the bottle? You know seeing that BP purchased the stuff - recipe, facility or whatever...
brads911sc 03-04-2012 06:43 PM
ah. the misinformation that flows on the internet.
Kendall today is not the same as Brad Penn.
Its owned by Connoco Phillips... and has enough of the ZDDP (around 1200 ppm) for our engines.
I have cases of brad penn in my garage as well.. got a great deal on Amazon.. but the "new" GT1 is a very good oil... has been tested over and over again... which is why its listed as acceptable on the monster oil thread.
It really hasnt changed in awhile...
brads911sc 03-04-2012 06:45 PM
Wrong
Originally Posted by reiver (Post 6600955)
the stuff he shipped overseas in 'the old days' is now b penn as they bought the kendall platform,,,,kendall is now reg oil not prop up to snuff for flat tap motors.
Reiver 03-04-2012 06:47 PM
Well I'll be flumoxed and hornswoggled....1200 ppm ZDDP!
uwanna 03-04-2012 06:49 PM
The Kendall name was purchased by Conoco some years back and they now produce Kendall products in their refineries. In the purchase, they did not buy the Bradley, Pennsylvania refining facility, and that facility is the one that produces the Brad Penn products. That refinery produces their products using the original Kendall formulas, ergo the Brad Penn oil is the old original Kendall product (that everyone has raved about) except with the Brad Penn name. I use nothing but Brad Penn in my car, and it is readily available in the Atlanta area, at great prices! Check this thread for details.
http://forums.pelicanparts.com/porsche-911-technical-forum/494379-attn-atlanta-area-pelicans-found-local-source-brad-penn-oil.html
brads911sc 03-04-2012 06:58 PM
Phosphorus, wt % 0.108
Titanium, wt % 0.010
Zinc, wt % 0.119
Above is the newest formulation... 20w50. I suppose that .119 is not the same as .12. (insert sarcasm...)
You are fine with easy to get GT1 or VR1. Best place to get brad penn on most days is Amazon if you have prime, because with prime.. shipping is FREE.
Steve@Rennsport 03-04-2012 07:54 PM
Finally, an accurate statement,....:) :)
What made the original Kendall GT-1 such a "magic" product was the unique base stocks pumped close to their refinery in NW Pennsylvania. Brad-Penn uses the same thing and its superior as a lubricant, compared to other like products. People who are far smarter than me attest to the qualities of Pennsylvania crude as used for oils.
As a consumer of the original Kendall products since 1965, I can personally attest to what they did that others didn't. Unfortunately, I have no idea what Conoco-Phillips uses in their current version of GT-1 race oil and they are not likely to tell me.
Given how expensive our engines are, I'll not use any other non-synthetic oil in a customer's or my own car unless I have no other choice.
Naturally JMHO,
Steve@Rennsport 03-04-2012 08:01 PM
Zinc, wt % 0.119
Depending on what valve springs are in use, you may not be fine with those percentages, based on what I've seen. Those are marginal for OEM springs, however aftermarket ones are stiffer and place more demands on the oil's EP package.
Canada Kev 03-04-2012 08:06 PM
Naturally JMHO,
OK, Steve, since you mentioned it (and hopefully not to continue another oil debate thread unnecessarily) what would your choice in synthetic oil be? :)
Steve@Rennsport 03-04-2012 08:39 PM
While there are plenty of choices, we use either Motul 300V 15w-50 or Mobil 1 V-twin 20w-50 oil. Both are exceptional products for the air-cooled engines with excellent base stocks and additive packages.
DRACO A5OG 03-04-2012 10:03 PM
Congrats Mark on the fix! I wish the best for you and your baby.
Not for noting, but I had the opposite issue, when I switched to BP I started to get chain tensioner noise, :eek: scary shiznet, switched to VR1 and never heard it again. Crazy I know, I really liked how BP kept my baby cool but the leaks were just unbearable.
If the noise rears it's ugly head with VR1, then I may have to consider Kendall GT1.
Question for the guru's, I did not know the original Kendall formula had 20% synthetic like today's Brad Penn?
Steve@Rennsport 03-04-2012 11:16 PM
The original Kendall GT-1 was purely a dino oil. I think Brad-Penn added the 20% synthetic content to improve cold flow.
tobluforu 03-05-2012 05:52 AM
I used the org Kendall oil but this was a long time ago, wasn't it some funky color like green?
mytoy 03-05-2012 06:44 AM
Blue
Steve@Rennsport 03-05-2012 08:40 AM
Yessir, thats correct. :)
Brad-Penn still is.
