H1 headlights.
Probably a dumb question but which of the two H1 bulbs in an H1
headlight acts as the high beam.The center bulb in the large round reflector
or the other bulb in the half moon reflector? On high beam I would assume they are both on and just the center bulb on low beam.
Thanks for any input.
Old 03-09-2012, 03:01 PM
Happiest when Tinkering
gsmith660's Avatar
Bottom bulb is the high beam and no they are not both on when on high beam.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 03-09-2012, 03:24 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Well, mine with the lo beams on and I pull to flash will turn both on but when pushed forward only the Hi's
'85 Carrera Targa
PCA/POC
Old 03-09-2012, 03:29 PM
AutoBahned
RWebb's Avatar
you can rewire if you want
be SURE to add relays
about the only thing the Haynes manual has over the Bentley is a nice diagram for adjusting the H1's
Old 03-09-2012, 03:35 PM
DRACO A5OG's Avatar
Haynes also shows you the order of the alternator fitment install , recently discovered.
'85 Carrera Targa
PCA/POC
Old 03-09-2012, 03:39 PM
gsmith660's Avatar
That is correct on the way they work
Old 03-09-2012, 03:42 PM
AutoBahned
RWebb's Avatar
ok, there are at least 3 good tidbits in the Haynes manual - I just checked the anti-Haynes rant thread started by kwm
here is my edited version of the H-1 headlight aiming diagram presented my Haynes:
Old 03-09-2012, 03:52 PM
