new struts- now wheel bearing issues??!!!
i installed new bilstein strut assmblys and i cant get the passenger side wheel bearing right. i have three different hubs and they all growl and shake. i dont want to screw up the new spindles. i checked the races w/a feeler guage to make sure they are fully seated. im starting to think that the spacer/seal race is on crooked or its bent or something. help
Jason
81 SC
97 328is
87 Jeep Comanche (RIP)
Old 03-07-2012, 12:27 AM
pete3799's Avatar
The O ring and spacer need to be pressed on. Did you check the spacer with a feeler gauge?
If the spacer is tight against the strut it's on straight.
Measure how much spindle is exposed (end of spindle to lock nut) on the driver side and compare to the pass. side.
Sounds like you haven't got the wheel seal seated on the spacer.
Pete
79 911SC RoW
Old 03-07-2012, 07:34 AM
i did check the spacer w/a feeler guage. i think i may have damaged it. removing it left deep marks on the back of the ring from the drift used to remove it, so i did a little cleanup on the back of it and that may have screwed up the dimension of the part. not sure- i ordered a new spacer, thrust washer and clamp nut, im hoping this will be it
Jason
81 SC
97 328is
Old 03-07-2012, 06:17 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Good idea. How simple is that?
Old 03-08-2012, 10:28 AM
ok- got the new spacer, washer and clamp nut on and it feels promising!! went for a test run and it was good. ill take it on the freeway 2nite and see for sure. after i got the spacer on and assembled everything the clamp nut did NOT go on as far as before. i was a little worried about that but it seems good. ill tell you what though- on the other side, with the new spindle and everything together it was actually hard to get play out of it. as soon as the nut was up against the washer there was no play what so ever and the washer was very easy to move. on this side that i worked on today there is a minute amount of play with the washer being easy to move
Jason
81 SC
97 328is
Old 03-08-2012, 03:32 PM
Member 911 Anonymous
DRACO A5OG's Avatar
If you need a second set of eyes for an opinion, pm me.
'85 Carrera Targa
PCA/POC
Old 03-08-2012, 04:55 PM
i will and thanks for that, thats kind of u. its been quite a frustrating problem, this wheel bearing issue. i was thinking about that yesterday- what if im doing something wrong and i dont realize it. going through all the motions by myself w/no one to tell me, hey dip**** why are u doing that?!
i think its actually fixed. my old spindles were so worn, so using any of those old parts w/new spindles is asking for trouble.
Jason
81 SC
97 328is
Old 03-08-2012, 05:31 PM
DRACO A5OG's Avatar
Don't sweat it Brother, plus nice to have company, it gets lonely sometimes
Wait old part? What are you re-using?
'85 Carrera Targa
PCA/POC
Old 03-08-2012, 11:45 PM
that was the problem- i used the old spacer, washer and clamp nut. im not sure which one was the offender but one of those parts was bad.
Jason
81 SC
97 328is
Old 03-09-2012, 02:06 AM
