Okay, silly tech question:
On the driver side of the engine compartment and just below the coil is a gizmo that has a lever controlled by a wire cable. It doesn't seem to do much on my car. The lettering on it includes VDO and Geshwin_ _ _ _ _ _ and some other letters and numbers I can't see clearly.
What is it, what does it do, and does it require attention? Thx much. |
How about a pic of the item?
My SC doesn't have such a gizmo.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
Yeah, I should have mentioned: It's a 1986 Euro version 911 Carrera.
Does it look like any of these bits?
Porsche 911 & Carrera Cables & Controls - Page 4 Click on the little pics to get larger ones.
Here's a couple pics:
On my 84 Carrera the only wire controlled item on that side is the vacuum servo for the cruise control. It's back behind the coil then comes the fuel filter and further back in the far back left corner is the Cruise control servo, it has a wire within a black shell (like a bike brake cable) that then routes to the throttle linkage on the Throttle Body. That's the only wire controlled device on that side of my engine compartment.
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
Never seen that before? Does this thing have vacuum lines or fuel lines attached?
Not only that but it looks like someone may have cut the plastic fuse panel cover to fit that part in, almost like it's not a stock part? Tell us more about this engine setup, does it have any modifications? Especially fuel related stuff?
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible Last edited by scarceller; 03-13-2012 at 06:31 PM.. |
It's part # 944-617-121-00-OEM in the link I supplied. Cruise control servo.
Sure is, looks like in 88-89 they used different servo than in 84-87 this is part # 911-617-123-02-OEM also in your link.
Basic care is all it should need, keep the shaft clean maybe a tad of WD40 on the shaft and also keep cable clean and slightly oiled. Other than that, if the cruise works it should need little care.
So it's a VDO cruise control unit? That's interesting, my car does not currently have cruise control or the lever for it that should be on the right side of the steering wheel per my owners manual!
