This sucks, front pan rust..
I always knew that there was rust in the front pan which was caused because of battery acid, but did not know it was this bad until I jacked the car up last night to look at something else. Started digging, and digging and digging and well it's almost time to replace these parts. Since I don't drive the car that much I'm going to hold out for the summer so I can have some fun, but it will have to go to a shop in the fall. Now, pelican offers three different pans from 160-600 which is kind of crazy and I'm sure other companies offer other pans as well. If anyone has done this what manufacturer have you gone with? Also, what else should be replaced down there besides that and the tank support? And, for anyone in the Chicago area, who would you recommend to do this job?
72 911 Although it is done at the moment, it will never be finished. Last edited by tobluforu; 03-08-2012 at 09:51 AM.. |
Restoration design is a common replacement pan, which I believe Pelican sells. The big part is the labor. It will cost you a lot to get this job done. Good excuse to buy a welder and do it yourself. It took me about a month and a half, working on it here and there. Get a sealed glass mat battery when you are finished so it doesnt happen again. Carefull driving it if the areas around the front torsion bar mounts are rusted out.
Doug 79 SC Targa w/ ITBs, 2004 Cayenne Turbo |
Enthusiast
Here is my suspension pan thread. If you have any questions feel free to PM me.
Jonathon 1982 911 SC www.avrmotorsports.com |
Thanks guys, saw that thread and did a search and it looks like st0dard$ has some good parts, but wanted to keep it in house at pelican. I think the 600 route that Dansk offers is a tad above my means and RD seems to be hit and miss. Has anyone gone the super cheap route that is supplied by Tasker, I see one good review?
I will not be doing this myself, no welding skills and I live in a shared garage. Now, if I had my own garage I would give this a shot, but my neighbors about freaked out on me last summer when I removed my engine/tranny twice.
72 911 Although it is done at the moment, it will never be finished. |
It cost me $2k total, parts and labor included, but it was done extremely well.
this is why I consider the most important feature of a battery is that it not leak - Right now I'm using an Optima. If it doesn't start the car, fine, just don't leak.... well not quite but close.
Sold: 1989 3.2 coupe, 112k miles |
I have had an optima style battery in the car for over 10 years, but the damage was already done before that when it had two batteries.
Max Sluiter
Gee, I would never feel comfortable driving, especially spirited driving, on a compromised suspension pan. It is a majorly structural part of the car. So a failure means crash. Don't drive very fast!
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
It hasn't crept into the torsion bar mounts; it's in the middle of that support, but yeah, no high speed racing for this car. Might be a good time to upgrade to rebel racing bushings while I'm in there.
It's not all due to battery leakage. The internal areas are clearly excellent water traps.
Do a search and read all you can. Replacing a pan is not rocket science but you can certainly make serious mistakes if you blunder into it without preparation.
Steve B. 1972 911t 1999 328is |
The Tasker pan shows its weight being 28 lbs. The Restoration Design shows 40 lbs. For the extra few bucks, I'd go with the heavier product.
The Dansk pan shows it being 10.75 lbs. That doesn't sound right to me, but it's too expensive nonetheless. If it were me, I'd go with the RD product.
1984 Targa |
I got the Tasker repro Oil cooler. While okay, I am not impressed with the quality.
Im scheduled to get mine done mid march and i bought the resto design part.
1975 Aubergine 911S - Barney "When that doesn't work, and it doesn't quite often, it's as though your face has been amputated." - Jeremy Clarkson |
I did mine 4 years ago. First got some green primer thing that was an ill-fitting joke with mis-welded nut plates. The got a non-galvanized, heavier pan from RD that seemed better made but also didn't fit well. Then got a Dansk galvanized pan, and it slipped right in and fit like a glove. If I had to do it again, I'd buy the nice fitting pan in an instant - the $300 - $400 savings isn't worth the hassle of fitting a crappy part.
I spent <$2K (I think) and ended up with a nice welder to boot - it isn't difficult, just time consuming. It was my first autobody project, and it turned out just fine - and I'd a retarded monkey with 2 left hands.
'88 Coupe Lagoon Green "D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen" "We must not allow a Mineshaft Gap!" |
PP, Who would you have do it in Vancouver?
Too many cars, not enough moolah... |
I'd be interested in that as well!
- 2014 Porsche Cayman - Guards Red/Black - 1986 Porsche 911 Carrera 3.2 - Silver/Burgundy - 1973 Porsche 911 2.7S - Aubergine/Black - 2200 lbs ! - 1980 Porsche 931 - Malaga Red/Black (sold) - 2015 VW Golf 1.8 TSI |
This is something that should be done on a Celette Jig and that will be the majority of the expense. I'd go for the dansk first second choice RD.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
Direct correlation between price and quality on the three pans. The Tasker piece is likely made in China, RD is made in Canada and Dansk is made in Europe. While the Tasker pieces can be ok, we like the RD products as offering a more consistent quality and finish. If you want OEM quality, Dansk is the way to go. Any one of these will be better than a rusty or damaged pan though.
George E. www.autoinno.com www.AIRMotorSports.com |
