-   -   Need help locating a condensor for a 2.2 S dizzie (http://forums.pelicanparts.com/porsche-911-technical-forum/664340-need-help-locating-condensor-2-2-s-dizzie.html)
tpickstone 03-09-2012 03:37 PM
My '69 T has an Bosch 007 distributor - the chart shows it as a 2.2 version. At some time in the car's history someone has taken out the CDI box (I am assuming that it had one) and it is now running with a coil/condensor package. Our host has not been able to find me a condensor so I thought I'd put a photo out there and see if anyone else has this setup and if they can point me in the right direction to find one - or maybe I need to rethink the system?
This is it:
http://forums.pelicanparts.com/uploa...1331336086.jpg
Thanks for the help
ddinham 03-09-2012 06:59 PM
Tpickstone,
I may have one of those. Any numbers on it that might help?
Dana
tpickstone 03-10-2012 07:26 AM
Dana,
I'll pull it out again and have a look for numbers on the condensor.
Thanks, Tim
tpickstone 03-10-2012 02:11 PM
OK, the condensor has no numbers on it and it is 1 inch long and 3/4 inches in diameter.
Thanks again for any help.
HawgRyder 03-10-2012 02:23 PM
Go to your local NAPA store (or similar) and see if they have Echlin or Bluestreak replacements.
Or...how about a Co-op (for tractor parts)?
Any automotive type condensor will work...all it does is reduce the spark across the points when they open.
Bob
zippy_gg 03-10-2012 03:53 PM
Some VW aftermarket shops may have the condenser you need.
There should be a value in Microfarad (μF) that needs to be matched, otherwise any other form factor will work.
ddinham 03-11-2012 10:35 AM
If you think either of these will work, I'll send one to you.
Danahttp://forums.pelicanparts.com/uploa...1331487300.jpg
