krshome's Avatar
rear seat and shifter console delete
Hey all, I'm looking for some help. I want to remove my rear seat completely, I do not want to install a rear seat delete shelf. What are people doing to give it a clean look. Do you just redo carpet and is it easy? As for the center console I would like to remove that as well, how and where are you moving rear defogger and hazard switches. Photos are the best. Thanks all
Old 03-13-2012, 06:03 AM
ivangene's Avatar
rear fog switch is under the passenger foot rest...I never seem to miss it - also hazard in same place but I have access to that one in case I need to hit the button....
I think its a poor execution on my part but it really hasnt been an issue...no new holes drilled, no goofy brackets and completely reversible
Ed M
86' Coupe
Old 03-13-2012, 06:14 AM
Undocumented User
McLaren-TAG's Avatar
Here's mine, cleaned things up a bit since then, painted the stick etc.
Old 03-13-2012, 06:28 AM
fred cook's Avatar
Seat delete...........
I did this on my SC recently. Removed the (entire) interior, put down some dynamat sound deadner and RS carpet set. In my car, all I had to relocate were the two a/c controls which I put in a panel where the ashtray used to live. The seats are by Corbeau (17 lbs each) as are the seatbelt/harness assemlies. Door panels are RS style with no pockets and strap door releases.
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 03-13-2012, 06:30 AM
