Always learning
Vibrating steering wheel. A process of elimination....
Hi
I've had new tyres fitted and the wheels a balanced twice. Yet, at 110kph the steering wheel vibrates..... Then I replaced the bearings. No change. Played with tyre pressures. No change What should I look for next? |
Shocks and/or bushings. If they have more than 100,000 miles on them it's time.
Kurt |
"O"man(are we in trouble)
warped rotor, wheel out of balance, could be shocks or alignment??
Always learning
Okay sure. New shocks, bushes, tie rods etc. all done.
Wheel alignment done professionally. Any other thoughts |
Alignments should always accompany wheel balancing in my opinion.
2007 Cayman 1986 Carrera coupe (sold) 1979 911 SC targa (sold) |
Always learning
Yes all of the above had been done. That's why I am stumped....
Member 911 Anonymous
hmmm, Try another tyre shop, possibly a custom shop. I had a chain balance my tires and I'd get horrible vibrations, went to a custom shop and they balanced it with a bunch of weights but did note my rims were bent.It improved but had the rims straightened and wow what a difference. They straightened it out so well it did not require weights
![]() Since all your components are new and slop free (right?) focus on the tyres and rims. Also, how is the two U joints on the steering column?
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Banned
What wheels do you have? I had a 914 long ago that had a vibrating steering wheel like you describe and I, too, replaced and did everything you mentioned . . . it turned out that the cheap, Empi style wheels were not truely round!
linear bearings
linear bearing in the strut or worn struts shaft?
79sc Flared with a 3.2SS conversion 9.5:1 J&E's with 964 cams and M&K exhaust Viper Green He who laughs, lasts. |
linear bearings
if the tires are true and the balance is right….
How old are your tires? I had a steel belt broken in older Desert Dueler tires (or are they tyres?) on my Landcruiser once. It caused the same vibrations that you described. Eventually the tire exploded. Fortunately it was on a rear wheel. But it did tear up the body around the wheel well! Otherwise I came out OK.
79 SC Targa 72 T Targa Sold 68 T Coupe Sold 65 912 Coupe Sold 62 356B Coupe Sold |
Pure Awesomeness
Mitch Leland steering wheel bushing to the rescue?
1977 Porsche 911 |
RETIRED
Ball joints.....torsion bars and/or bushings....yer GF's vibrator that is set on stun?
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Too damned funny Joe Bob.
Don Newton “People sleep peaceably in their beds at night,” George Orwell wrote, “only because rough men stand ready to do violence on their behalf.” "I gave up visiting my psychoanalyst because he was meddling too much in my private life." Tennessee Williams |
Fleabit peanut monkey
You have a 1965 912 with a 3.2 motor in it and turbo "springs" to offset the added weight of the larger engine per your garage info.
Did the front end work ok with this configuration before? |
Always learning
Thanks gents. Tyres are new. Bearings are new. U joints appear good - how do I check?
Girl doesn't need a vibrator thanks joe! Might swap the wheels with the rear... Last edited by rolls 912; 03-10-2012 at 03:29 AM.. |
Of course she does,.....you just haven't found it yet.......
Neil 1987 Carrera, Grand Prix White, 2009 Carrera C4S, Meteor Grey Metallic (X) [B] 2011 BMW X5[B] 'Success is not final, failure is not fatal. It is the courage to continue that counts' |
RETIRED
If'n ya pull one sparky on that four banger, all problems are gone....
![]() BTW, since the wheels are the same size.....nice to be able to swap them.....have you ever done a spin balance with the tires on the car? Old school tire/alignment shops used to do that.
Always learning
I was thinking about that but no one around here uses those machines. Might need to dig deeper- good call.
RETIRED
Alloy or steel wheels?
