Oil line nuts, what size?
Does anyone know what size the nut is, at the oil tank and oil cooler pressure relief valve is on the oil lines? The car is an '84. Thanks.
Dean Last edited by 911dean; 03-13-2012 at 03:38 PM.. |
![]() It depends on the model year. 1971 911s actually used both 26mm and 30mm threads. Earlier models only 26mm and later models only 30mm. Wrench sizes are 32mm for early and 36mm for late. I know because I make up custom oil lines & hoses for the early models 911. Len
36mm
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Thanks for the info!
dean |
Reiver
36mm on my '83...had to grind an extra 34mm wrench to change out the oil cooler.
