Source for 1974 fuel pump
I think that my fuel pump is failing. The car lunges and bucks and the fuel pump makes a loud buzzing sound that is not normal. Does anyone have any words of wisdom as to the best source for a fuel pump?? This is a 1974 911 CIS 2.7. Pelican has a piersburg but says it need minor modification automation has one that is rebuilt...?
76 911S Targa
I have had good luck calling the guys at Pelican and simply asking them what they recommend. Why not try that?
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods. |
have you already checked your fuel filter for pluggage?
Taking it apart is easy
I like that word, "pluggage". I'm going to add it to my dictionary.
Jerome PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com |
The fuel filter is fairly new, and the pump is making a racket that it had not done previously. I have the filter on order as I write this but due to the noise frome the pump I have to assume that it is the cause , as the noise and the bucking car came at the same time. I was on a 2 hr drive and only at the end did it deteriorate and the pump started to buzz much louder and differently than normal!
Speed Dog's Chauffeur
Got the number?
Call Pelican to see what the modification involves. It may just be a simple fitting or hose adapter. New pump is the way to go. You can also post the Bosch number and a pic to see if someone has a NOS or an old one in the garage.
ROW '78 911 Targa
Type oemfuelpumps dot com into your search engine....
![]() These are a nylon screen unit and always ignored. When they get plugged with dirt and/or rust, the pump cannot draw any fuel and gets noisy as it starves. Drain the tank and change that filter before you condemn the pump.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Ok will do the tank check
Almost a certainty that your tank is rusty. Pull the fuel sending unit and look inside.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
The fuel pump in my '75 is acting up and both of the fuel filters are fine.
Has anyone actually used one of the universal Pierburg pumps that Pelican sells for the '74-'76 cars? I called them today and spoke with two different folks, and neither could tell me what the "minor modifications" were for installation. I noticed that a Genuine Porsche piece is available for $600 or so, but turns out they are Chinese Bosch units (and very expensive to boot!). Last edited by drtyler; 03-14-2012 at 02:21 PM.. |
Replaced the fuel pump in my '75 last summer. I had thought about the universal replacement from our host but ended up sourcing an original style through Vertex in Florida.
New: Porsche New Fuel Pump For Cis Injection: Fuel Fuel Injection & Fuel Pumps, Injection Relat Rebuilt: Porsche Rebuilt Fuel Pump For Cis Injection: Fuel Fuel Injection & Fuel Pumps, Injection Relat They're pricier than the universal versions but I had no interest in making changes to my car's fuel plumbing and electrical. One caveat though. Make sure that Vertex is sending you the correct pump as they accidentally sent me the universal one at first even though they'd charged me for the factory one. They were very good about fixing the error but it cost me about 3 weeks of enjoyment of the car while the pumps were being shipped back and forth.
1979 911SC "Frankencab" Dave |
grateful user
"The Fuel Pump King" in cali. is the best source of new bosche pumps that i have found. He cant hardly understand english, put if you give him the number on the old pump he can fix you up. Just got a new in the box bosche for an 80 sc..150.00 delivered.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do. |
ROW '78 911 Targa
$ 100.00 delivered to me in Oregon... Worked for me, I can burn up 3 of them for that price.
(Yes, I did buy one from there)
