carnut169's Avatar
Do I need shocks?
If you read my recent post about tires you know that I just purchased a new set of Kuhmos. I ended up buying a whole set due to a rear tire blowout because my front tires were cupping. When I purchased the wheel/ tire combo I had an alignment done and a high-speed balance, but the ContiSportContacts wore out in 8 months and 6,000 miles! Do you think that my car might need shocks? It has 65k on it now- but the front does not "bounce" up and down. What else could cause the front tires to cup?
Sean O.
Atlanta, Ga.
96 Van Diemen Formula Continental
01 2500HD
Old 04-24-2002, 07:06 AM
Sean Hamilton's Avatar
Tyre Inflation?
I'm hardly a Guru on this Sean, but do you mean Concave - wear at the tyre edges and therefore under inflated? Or convex - wear at the tyre centre and therefore over inflated?
Inner or outer scrubbing I think means alignment / camber / caster / toe?
have I got that the right way round?
Somebody?
Cheers, Sean.
94 911 Carrera 2 993 Cab
http://www.pelicanparts.com/gallery/Sean_Hamilton
Old 04-24-2002, 07:45 AM
Senior Member
Superman's Avatar
I was the one who suggested that toasted shock cause tire cupping. By cupping I mean that each of the hundreds of tread "mesas" ended up shaped like a cup. I'm not talking about wear in the middle of the tire, or on the edges. To me, "cupping" means the tire has many, many areas where the tread has worn into a bunch of cups. As far as I know, the only way this can happen is if the tire has actually been bounding up and down due to a shock that is effectively not even there. If a shock is operable at all, it will keep the tire from actually bounding and cupping. You've seen cars like this on the freeway, haven;t you? Where the tire is actually bouncing up and down on the road surface. I think it would be unlikely that both your front shocks are inoperable.
As a side note, this is the shock's job....to keep the tire against the road. Not to keep the car from rolling side to side, or bouncing or whatever. The job of a shock absorber is to keep the tire firmly against the road surface at all times.
Go to a tire store to learn about cupping. I suppose there could be other causes. Again, I suspect we're talking about different things.
Mocha 1978 911SC. "Coco"
Old 04-24-2002, 08:08 AM
carnut169's Avatar
Neither. On the inside edge of the front tires they are "wavey"- in other words they have high and low areas.
Sean O.
Atlanta, Ga.
01 2500HD
Old 04-24-2002, 08:16 AM
carnut169's Avatar
I can post a photo later if you guys do not know what I am talking about.
Sean O.
Atlanta, Ga.
01 2500HD
Old 04-24-2002, 08:20 AM
Senior Member
Superman's Avatar
I photo would probably be helpful. There are many others who know much more than I about suspensions and tires, and that would include the more experienced tire guys at the local tire store. But there is a wide range of competencies in the tire store industry, so ask your local trusted mechanics who they take their cars to for alignment.
Old 04-24-2002, 08:26 AM
