Me again, I can replace the sway bar without the stone guard. I drive the car on the street. Do I need it?
Old 05-12-2012, 11:42 AM
It's all about technique.........
Originally Posted by tazzieman View Post
Without a hoist it's a prick of a job - I used my 12 yo to insert the bolt whilst I held it all aligned (prying on the bracket to line up the holes)
Tazzieman has given you a good tip. Specially if you are doing the bigger 24 mm front sway bars. I'm a super senior citizen (old) with a bad back and knee and weighs only 138 lbs. yet, I could install these 24 mm Carrera sway bars by myself!!!! Use a device like a chain hoist or a heavy duty come-along to flex or bend the sway bar like a bow so that the other end of the bar line ups with the rubber bushing. You start with one end of the sway bar in place and line-up the other end by pulling both ends closer (inward) till you get the second end inside the rubber bushing and release the tension. I couldn't even carry a golf bag so you could imagine that you don't need strength to accomplish this project.
Tony
Old 05-12-2012, 11:50 AM
I have no problem installing the sway bar without the stone guard. Unless my stone guard was previously installed wrong, the bolts holding the guard are used on the bushing clamp and cannot be pryed on or reached when aligning the stone guard. The guard covers the sway bar and busing clamp bolt holes.
The question is do I really need the stone guard which protects the fuel pump and steering mechanism?
Old 05-13-2012, 08:20 AM
French Import
zippy_gg's Avatar
I think you've answered your own question. I would not considered driving my car in the mean streets of Los Angeles, with steep driveways and bad roads, especially if your car is at Euro height or lower.
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 05-13-2012, 08:34 AM
Hey guys, thanks for the tips. I just unistalled the bolts one by one and slipped the guard on. Much easier to realign the bolts to the guard once the bar is installed.
Bob
84 Cab
Old 05-19-2012, 09:38 AM
