Twist sockets are the cat's meow! Worth their weight in gold!
See this thread here too. http://forums.pelicanparts.com/porsche-911-technical-forum/626404-stripped-10mm-cv-joint-bolt-question.html |
I had a similar issue, but ended up being able to hammer the hex socket into each fastener and break the torque. I will replace them upon re-assembly.
To avoid striped allen heads in the future, throw them away and get some torx instead.
Why couldn't you use an arp equivalent like a header bolt with a smaller head. It will not fill up with debris.
| All times are GMT -8. The time now is 01:25 PM. |
