removing rounded CV bolts
What is the best way to remove CV bolts when the socket head has been rounded out?
On person has told me weld a sacrificial #6 allen wrench?
Vise grips are not working.
Thank you.
John- 78 Slick Top 930
"Illegitimi non carborundum"
Old 03-14-2012, 09:15 PM
dtw dtw is offline
GAFB
If vice grips don't get it, use a Dremel to cut a slot in the head and use a big monster screwdriver. If that doesn't get it just cut the head off with a Dremel.
Old 03-14-2012, 09:20 PM
Thanks. I'll try both. I didn't think of the "slot" thing. I have an impact screwdriver that might help. Of course it's off the car to make it more difficult to hold the axles.
That would be an after pot of coffee task...
Old 03-14-2012, 09:23 PM
Dr J's Avatar
I used vice grips on one occasion. For the really tough one, I had an impact hammer and was hitting it at an angle to get it to rotate.
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged!
Old 03-14-2012, 09:29 PM
What a pain. Who ever installed these must have put them in with an impact. There are four total. One on the trans side the other on the trailing arm.
Old 03-14-2012, 09:35 PM
Here is the link to where I asked the same question last fall...
stripped 10mm CV joint bolt question
I ended up using the dremel and a reinforced cutting disc. after the cap screw head popped off, everything came out easily.
Good luck
mark
Old 03-14-2012, 09:36 PM
Functionista
manbridge 74's Avatar
I like to use a product called Screw Grab whenever I think that the fit is too loose between allen wrench and head. It feels like valve grinding compound but way coarser.
Saves many headaches beforehand. Was doubting its ability till I tried it.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 03-14-2012, 11:04 PM
I've used that stuff and it's great for phillips head screws, but this is beyond that.
Old 03-15-2012, 05:00 AM
PCA7GGR's Avatar
air chisel?
Sergio
The GT Lid Whisperer
PCA 42yrs - National DE Instructor / Ex-RGruppe #197
'19 718 Cayman S (9th Porsche/1st with PDK)
'14 Subaru Forester XT (Porsche support vehicle)
Old 03-15-2012, 05:09 AM
One simple tip:
If it is the last bolt, put a few of the other bolts back in so there is less pressure on the stripped bolt.
1972 911T targa
Old 03-15-2012, 06:43 AM
I ended up cutting off the heads with a die grinder fitted with a thin cut off wheel. Took about 15 min to get them all off. The studs (left over bolt) just spun right out by hand. The heating and cooling must have loosened them.
Thanks for the help.
Old 03-15-2012, 11:37 AM
1980SCMan
Alan Lindquist's Avatar
I've wrestled with a few of those. If you catch them early enough - like the allen wrench just doesn't feel solid, you can put a small piece of aluminum foil over the hole and tap the allen wrench in. You may get enough bite to crack it loose.
Old 03-15-2012, 12:45 PM
AutoBahned
RWebb's Avatar
For Future Reference...
1st thing - smack it straight on a good ringing blow with a steel hammer, then try
2nd - if that does not work, then heat it with a torch, then try (crazed PO may have used red Locktite or something stoopid instead of following the correct installation procedures)
afterwards, try the above, remember: Impact is your Friend
Always:
1. be sure the bit is nice & sharp, so dress it on a grinding wheel and inspect carefully
2. clean the "female" wrenching fixture on the Allen head cap screw out carefully with a pick and/or Q-tips
Old 03-15-2012, 01:10 PM
safe's Avatar
I recently bought a set of these:
Smack them on any damaged nut with a hammer and they will take anything of, I bet they would work on allan bolt also.
Love them!
Magnus
Old 03-15-2012, 01:27 PM
Undocumented User
McLaren-TAG's Avatar
Just recently did my CV boots and I didn't even take a chance I replaced all 12 bolts upon reassembly, for the under $24 expense the next time I did it, I wanted fresh heads.
Old 03-15-2012, 01:34 PM
You know I have some of those nut removers and I didn't even try them.
I like the alum foil idea. Hopefully, I will never have to try it.
Funny on replacing them, I almost never reuse those. I fortunately found that I purchased a huge quantity of them in a purchase of hardware from a place closing down. 12.9 hardness. They will work.
Old 03-15-2012, 02:40 PM
trak ratt's Avatar
Cut off wheel and/or chisel. I usually cut as much as I can then chisel the rest. Relatively easy and quick. Be careful not to cut into the CV.
Old 03-15-2012, 03:00 PM
kodioneill's Avatar
Had to do it the other day on a 70 914/6 nothing worked had to use a torch to cut the head off.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 03-15-2012, 03:10 PM
vash's Avatar
Love them!
+1000..these make the issue a non-issue. you will literally be giggling as they come loose. buy them.
poof! gone
Old 03-15-2012, 04:47 PM
Had a set of those which were stolen from garage, along with about $3,000 worth of other tools. It's those lilttle things that you forget got stolen till something like this comes up and you look and look then it hits you...damn, one more thing I'll have to buy TWICE!
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 03-15-2012, 04:54 PM
