Canucks Fan
Question Hood shocks question
Hi
I bought front hood shocks a couple of years ago and I'm just needing them now. I tried to compress the shocks and couldn't, I didn't give it full force but I was expecting to be able to compress the shock with moderate pressure, whats' up ? Are mine "frozen" out? How much pressure should it take to compress new shock struts?
Finn
From the Deep Dark Jungle
Old 03-16-2012, 09:39 AM
It takes considerable effort to compress new hood shocks, more than I would wish to use with my bare hand on the end of the shock.
Simple install them, one at a time, lower end first (the driver side can be "interesting", do a search for procedure), then lift the lid slightly to allow the end of the shock to align with the bracket on the lid and install the pin.
Jerry M
'78 SC
Old 03-16-2012, 09:59 AM
80's Fan
I like to use a combo of magnets, locking pliers and pick/hook tools for this sorta job, and the pass side (if so equipped) is easier without the airbox lid in the way on 3.2's
Old 03-16-2012, 10:04 AM
If you can compress them with your hands than they are worn out. Same for the ones in the back.
'86 Carrera Cabriolet Grand Prix White
'09 VW Beetle Convertible
‘24 Audi Q8 etron
Originally Posted by s_morrison57 View Post
Hi
Finn
They should compress when connected to the car. Otherwise, they'd be too "soft" to support the weight of the hood.
You should be aware there are other alternatives to support the hood and deck lids.
Sherwood
Old 03-16-2012, 02:30 PM
Senior Member
Jdub's Avatar
It doesn't matter - this is a fool's dream, that these hood shocks will ever, ever work over time. Don't care who makes them, whatever - you would do better with a 1969 MG rear trunk set/re-set rod that toggles between up (pull) and down (pull again, then down).
Utterly, totally, willfully and mendaciously wretched items from the bum of Satan. Don't even bother - get a feckin' broomstick.
'78 Targa in Minerva Blue
Old 03-16-2012, 04:06 PM
Burnin' Rubber
Koizumi's Avatar
Well said I use the Seine Systems 'Ultimate Strut'.
Old 03-16-2012, 05:35 PM
Member 911 Anonymous
DRACO A5OG's Avatar
3/4" PVC, length of a strut, light weight to carry with you or longer to accomodate both front and rear, I had both
The only thing is to remember to remove it before closing the lid
Used for many years until recent strut swap.
'85 Carrera Targa
PCA/POC
Old 03-16-2012, 06:49 PM
Fb = M/S
aoncurly's Avatar
Word of caution - as you remove your old shocks, watch out for the nylon bushings on either side of the top end. I lost mine as they fell into some never-region of my car as I pulled out my old shocks.
Old 03-16-2012, 07:49 PM
Danny_Ocean's Avatar
I had one until it failed...when the alignment mechanic SLAMMED THE HOOD! F-er denied it when I discovered two weeks later and returned to the shop.
Old 03-16-2012, 09:02 PM
Banned but not out, yet..
RSBob's Avatar
Ditto - no more messing with struts, pins, and hassle just to have them die in a year or two.
Old 03-16-2012, 09:37 PM
Banned
I'm surprised anyone thinks it is difficult to change the struts on either lid - and they are relatively inexpensive, too. It's hard to believe that they actually piss people off!
Old 03-16-2012, 10:03 PM
Driver
Noah930's Avatar
Anyone have a recommendation for a hood shock? Regular? SS? Weltmeister? Or do they all randomly fail again in a few years? My stock ones (presumably 25 years-old?) seem to be slowly giving up.
1990 Black 964 C2 Targa
Old 03-16-2012, 10:09 PM
Banned
Mine are branded "Meyle" and are made in Germany . . . I think I bought them from Pelican . . . they are over four years old and going strong.
Old 03-16-2012, 10:19 PM
Mad scientist
Peter Bull's Avatar
After having had the hood catch dig into the nape of my neck a couple of times, I understand why people get mad.
I got a pair with a lifetime warranty some years ago, which don't work anymore. Which is surprising because I got a pair of struts for the rear lid when I bought the car about 12 years ago, and they still work as they should.
/Peter
'84 911 Carrera
'91 928 S4
You can't make a racehorse out of a bull, but you can make an awfully fast bull.
Old 03-17-2012, 12:07 AM
