Steve W's Avatar
Question How can I tell if Bilsteins are shot?
I've got factory green Bilstein sports all the way around on my 3.2 Carrera, however I'm starting to wonder if they may be going bad or loosing pressure because the front end doesn't seem to ride as tight as I used imagine it - but then it could just be my imagination. I think I once read that Bilsteins either work or they don't, and when they go out, they just fail. So a couple of nights ago I disconnected both front Bilstein struts from the shock towers and tried to see how much if any gas pressure there was in resistance to compression by hand. It took me some, but not too much effort to compress both fronts, they gassed back up to full extension, and they both felt somewhat the same. I thought they were supposed to be very difficult to compress by hand. So, does anyone with more experience with these know how to tell if they are worn out? If so, anyone have any experience with having Bilsteins rebuilt?
Old 04-24-2002, 02:27 PM
89Targa's Avatar
I recently put some new green Bilsteins on my car. As a point of reference, it took a significant amount of downward pressure to compress them enough to go under the fender lip. if I relaxed the downward pressure during the process, they immediately shot up to full extension.
Tom
'97 Turbo
'89 Targa
'04 Audi S4 Cab
'03 BMW 1150RT
Old 04-24-2002, 03:19 PM
Steve W's Avatar
So it seems then that my front shocks are dead. As a point of reference, do the rears shocks compress and rebound in the same manner?
Old 04-24-2002, 05:52 PM
89Targa's Avatar
Yep.
I checked out your Pelican Gallery page. Nice looking car, except for that USC license frame...
Go bears!
Tom
'97 Turbo
'89 Targa
'04 Audi S4 Cab
'03 BMW 1150RT
Old 04-24-2002, 06:01 PM
Steve W's Avatar
You are halarious Tom! That's ok though, envy is something I am used to.
Old 04-24-2002, 07:58 PM
Send them out to be revalved. You will have a perfecty working shock for about $85 per.
Old 04-24-2002, 08:43 PM
Steve W's Avatar
I think I will do that. They get sent to Bilstein for rebuilding, yes? I assume you mean the costs are about $85 each shock/strut?
Old 04-24-2002, 09:07 PM
Most places will do this for you if you don't want to go direct to them. I think the price is the same regardless at $85 per shock.
Old 04-24-2002, 09:16 PM
Navin Johnson
TimT's Avatar
I just had mine done
$110 per pair + shipping
'69 911 GT-5
'75 914 GT-3
and others
Old 04-25-2002, 04:29 AM
How long does a rebuilt pair last compared to buying them new? Is there a source for buying rebuilt bilsteins?
John Mogavero
'85 911 Targa
Old 04-25-2002, 04:47 AM
My brand new Bilsteins (all four) could be compressed by hand, and would fully extend on their own in about 3 seconds (more than enough time to get them back under the fender. I doubt yours are bad. You probably should give the Bilstein techs a call. As I understand it, their test procedure is quite rigorous.
Graham Archer
83 911SC Cab
Old 04-25-2002, 07:25 AM
Steve W's Avatar
Okay guys, now I'm all confused and unsure if my shocks are shot or not. Anyways, Tim, where did you have yours rebuilt at?
Old 04-25-2002, 09:47 PM
dickster's Avatar
steve
i've got four ready to go in. they are very hard for puny old me to compress. i'm replacing boges which are relatively easy to compress.
i'll check them over the weekend.
anyways how many miles you got on them??
Rich
'86 coupe
"there you are"
Old 04-26-2002, 12:22 AM
Steve W's Avatar
I pulled them off my former '84 Targa which had 125k miles, so, I'd guess something like 145,000 miles. Mine didn't take that much to compress, maybe like 25-40 lbs, I could hold it in place pretty easily, release and they would gas back up to full extension in about 3 seconds.
Old 04-26-2002, 02:00 AM
Navin Johnson
TimT's Avatar
Steve,
I had Bilstein rebuild the shocks, I took the inserts out of the struts and shipped them to Bilstein in San Diego (do a web search for the phone #) . They freshened up the shocks and revalved them for me. you'll need to tell them the weight of your car and the the intended use, (track, street). and the corner weights if you know them.
The reason I had my shocks rebuilt is my car weighs about
1900 lbs, and the shocks were valved for a 2500 lb car.
the turn around time on the shock rebuild was really good, like
1 1/2 weeks
TGIF
'69 911 GT-5
'75 914 GT-3
and others
Old 04-26-2002, 04:39 AM
dickster's Avatar
steve,
i'd say 145k is a pretty good indicator that they are well beyond their best!
imo you need new shocks
Rich
'86 coupe
"there you are"
Old 04-26-2002, 04:57 AM
