Rennline Adjustable Pedals
Rennline Adjustable pedals.......................should I?
Anyone have experience of these, do they really make for much easier Heel & Toe?
Cheers Beaky |
It's an interesting question. I certainly gave it some thought , but came to the conclusion that if Walter Rohrl "Rally driver of the millenium" could use a pretty basic setup (see other thread) then my issue was not so much the pedal makeup , rather a matter of practise makes perfect.
In the end I went with the 935/917 style throttle pedal because again , if it was considered good enough back in the day... There are of course different styles of H&T and as others have alluded to , different sizes of feet and types of footwear. |
Rescuer of old cars
My car had the Rennline pedals on it when I bought it. Since I thought the aluminum/red pedals looked a bit too 'bling' in the basic brown/ivory interior, and the original pedal and pads also came with the car, I reverted to stock. Drove it stock for about a week, and decided that I wanted to put the Rennline throttle pedal back in. After driving it for a couple of weeks with Rennline, that week w/o just felt wrong. I ended up painting the pedal black, and leaving the stock rubber pads on the brake and clutch. May still do a bit of fine adjustment on the throttle, but overall I much prefer the Rennline over stock.
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
Racer
No pics to hand right now , but check D Zug.
I made a small RSR style dead pedal from stainless, removed the brake and clutch rubber pedal pads and the whole setup looks neat , without bling. In driving shoes you can really feel what's happening underfoot. |
Racer
Never mind...I used Google and found them. Thanks, Scott Last edited by winders; 12-18-2011 at 04:38 PM.. |
Max Sluiter
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
MBruns for President
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
I have them (the Rennline adjustable gas pedal and clutch/brake) and like them very much. I was considering the "pedal extension" from Rennline but I'll probably continue to tweak the heights of the brake and gas first. IE. I still think that l can improve my pedals set up. Cheers
Racer
I have the AJ-USA dead pedal and my clutch and brake pedals do not have rubber pads. The stock gas pedal is okay except that the top, where I want to roll the outside of my foot, is too far away from the brake pedal. I don't need an extension at the bottom of the pedal. In fact, I don't get that concept at all. It seems like a safety problem to me. Anyway, I am looking for a gas pedal that I can get closer to the brake pedal. I like the idea of a smooth aluminum surface like the D Zug pedal. The gas pedal doesn't need grip. Thanks for the suggestion! Scott |
I did a bunch of research on Rennslist, and consensus was that this is the Cadillac (bad GM analogy?) of fully adjustable pedals.
I have struggled with heel/toe shifting since I got the 993 ( vs. my previous 924S), but have come to the humble realization that I need more practice than I need more gear. It's a real well-made piece though... Check out the Rlist threads that discuss it. This would be a great opp for someone to buy new, for less. |
pic as requested. I'm still finding my way with this but I really think practise is the key. It's all in the timing and you need quick reflexes. Like most motor tasks , 1000 reps creates the neural groove. Of course if you have bad habits , add another 1000
Unlike my 1988 Coupe, my 1993 964 Coupe came with these adjustable pedals. I love 'em!
88 Venetian Blue Coupe "B"--gone, but not forgotten 93 964 C2 Coupe "BNC" ("PNC" on some days!)--PSS9s, Big Reds, Strut Brace, Recaro SRDs, Schroth 5-pts, DAS bar |
Northern Motorhead
Hey Tazzieman,
Is that a homemade dead pedal ? I like it,do you have any fabrication info and dimensions,it looks like a nice Winter project !!! Cheers ! Phil
Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 |
Formerly known as Syzygy
I believe it to be a repro of the original factory piece from the '60s/early '70s. There is a guy here that's made them and is selling. After I checked out what his name was, I discovered that Pelican carries the part: Pelican Parts.com - Drivers Dead Pedal/Footrest.
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
Paul's products (Rennline) are well done and do the trick for me. I have them in both cars. The gas pedals I have are non adjustable, but you can adjust the brake pedal height at the cluster.
Racer
The search continues.... Scott |
For the gas pedal, is it width or height you need? I need height. I have not yet had a chance to try screwing a second rubber pedal to the first, but I understand this is a popular solution for those who find the gas pedal too low to get to; you can also offset it slightly to the left if you desire.
'74 Euro Carrera * '64 356SC Coupe |
Thanks folks, good responses.
I can't seem to locate a UK or European based distributer for the Rennline, (postage and duty really pumps up the cost) so may try a fabricate one first before a dip into my pockets. Does anyone have the Dimension of the pedal?
Cheers Beaky |
ajusa makes pedals that you can attach to the existing pedals, this allows you to move the brake and, or the gas pedal closer together. Before I went this way I just added a thin block of wood.
72 911 Although it is done at the moment, it will never be finished. |
