Four post lift engine drop
hello all, who has a four post lift that has dropped an engine without retrofitting the lift?
John Brasfield 91 C2 78 SC For sale 76 3.6 68 Datsun 2000 Mr. Magoo, 02 330ci |
Hi,
I can't say I've done it but am planning it for very near future. I have a Gemini which I think is typical. The 'stock' lift does not have even close to enough room between the rails to fit the 911 engine (with 914 engine sheet metal in my case.) Like you I hope to hear from some experts, but my plan is to take the rail without the hydraulics, unbolt the 2 bolts from each end, physically turn it around (to effectively remove the inside protruding lip) and move it out as far as possible, drilling new holes. This gives enough room with about 2" to spare.
Mark S. '70 914-6 |
Platinum Member
I have.
No big deal, jack car from bed of lift, rest engine on lift, slide out the back. |
engine drop
I moved one rail ( the one with out the cylinder) 2.5 inches to the side and re-drilled the rails.
Center the car on the hoist and just drop the engine onto a roll away work bench |
There is also another method used by Ferrari people to drop the 348 engine. It involves "hanging the rear of the car way back over the end of the lift" Sounds unsafe, but actually quite safe.
have not tried it myself. I got so used to doing it on the floor that I would just do it that way.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
I've done it many times, but all I can say is that it "depends on the lift".
Mine has a floating skid so I can set it wide enough that the tin ect clears no problem when lowering. I've seen others with notches in the placement, one to big one to small..
1975 Carrera Coupe #391 1980 924 11k orig miles 1974 914 2.0 LE Creamsicle 1979 Dodge Lil Red Express 2015 Wrangler Unlimited, and a bunch of bicycles. |
4 post lift
I have the smallest 4 post lift that Eagle Equipment makes (don't remember the exact model) and I have dropped the motor from my 70 911T (2.2L) with no clearance issues. I had a couple of inches to spare on each side. The motor was complete when I removed it- ie, with full exhaust. Hope this helps!
WK Carson |
Is it the Eagle GLO- 9000?
I watch the video (Eagle 7000lbs), wow convenience, but how come it lift SO SLOW?
Fat butt 911, 1987 |
lift
John,
It is likely the equivalent to the GLO9000- but on the Eagle website, the GLO-9000 is blue, where as mine is black. I bought it back in 2005 and it was the same price as the GLO-9000. I would simply have a look at mine to get the info, but it is back in the USA and I am currently in Okinawa Japan (US Navy MD stationed here). Also- my motor also had all the engine tin still on when it was dropped- that's actually the widest part of the whole thing. The lift is slow because it uses a hydraulic pump/piston system to drive a cable system to lift the car. It's not that big a deal to wait a minute or two while it's lifting. In fact the slow speed of it was a saving grace in several situations when I was lifting the car up pretty high and the roof of the car was near the ceiling. Had the lift been really fast, I'd likely have run the car roof into the ceiling and been paying for major dent damage repair on the car. Keith |
Home of the Whopper
Hmm, I dont have any problems on my inferior scissor lift.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller |
my cheap side(the one i am famous for) likes the scissor, my having used it side says 2 post but my pratical needing storage says 4 post. please list your brand if you can.
thanks
4 post for parking is great. 2 post or scissor for serious bottomside work...
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
That's what I was going to ask, about how do you feel while waiting, base your experience.
Thanks. Quote:
car hitting the ceiling
"""I'd likely have run the car roof into the ceiling and been paying for major dent damage repair on the car.""""
I only have 114" ceiling height and if I am not careful I drive the upper car into the rafters. To prevent this, I build a optical sensor system to cut out power to the lift, when the upper car is 1" from hitting the dry wall ceiling. |
more info on the sensor, what a great idea!
check this video out claiming an hr to drop with 2 post lift:
$35 and a six pack to my name..... '88 Diamond Blue Carrera CE 3.4-SOLD
I see 2 poles lift, and I see some cracks on the concrete floor. I feel scared. What's everyone's thought?
I didn't use the lift to remove the engine (as my car came without one). However, here is a posting of how I installed the engine using a 4 post lift.
Engine Going in Tomorrow!
1976 911S; 1957 Mercedes 190SL; 1982 Ferrari Mondial Coupe; 1991 Nissan Figaro; 2001 Panoz Esperante ; 1969 Pitts S1C http://forums.pelicanparts.com/porsche-911-technical-forum/664950-1976-911s-garage-find-road.html |
Easily do-able with a BendPak HD-9 lift and the rails moved to their outer-most position.
'73 2.0 914 (2.8 /6 conversion in progress) '64 356SC '65 Ducati Falcon 80 ‘19 Audi SQ5 |
