5:04's Avatar
Options for fiberglass sunroof panel mounting
I searched and while I found various threads on the removal process, I saw almost nothing on the installation of the fiberglass panels. I'd like to see what you guys have done. I have removed all of the metal from the sunroof housing and all that is left is the opening. Interior and exterior pictures would be appreciated.
Thanks!
Amir
that911.tumblr.com
Old 03-20-2012, 10:37 AM
Disbanded
juanbenae's Avatar
couple examples of panels done in linked thread. page 2 & 3 have both mine and another spec builder's approach. who did you get the panel from? the one i used was the same exact size as the factory panel so it was a bit small where the felt seals used to go. if you found another version that fits tight id be interested in the source of this and i would consider a do over. good luck
the plunge!
Old 03-20-2012, 10:47 AM
5:04's Avatar
Thanks for the info, and great build!
that911.tumblr.com
Old 03-21-2012, 03:08 PM
