-   -   Electrical wires HOT found when rep'l turn signal switch...what is it...?? (http://forums.pelicanparts.com/porsche-911-technical-forum/667713-electrical-wires-hot-found-when-repl-turn-signal-switch-what.html)
911 tweaks 03-25-2012 08:33 AM
working on an 87' Carrera...anyone know what these hot wires came or go to...??
Looks like they came out of a broken connector or lited something or switch...??
When I was installing the new turn signal/headlite hi/lo steering column switch, I see this arking happening...WOW I say to my self...this 2 pin hot wire is part of the wire set that has the Blk/Purple wire as part of its bundle...
Anyone know where this came from...?? I am sorting out a TON of electrical stuff so I guess it could come from anything...
Thx, Bobhttp://forums.pelicanparts.com/uploa...1332689474.jpg
86 911 Targa 03-25-2012 09:17 AM
pm
pm sent
911 tweaks 03-25-2012 09:45 AM
pm replied to...Thx, Bob
911 tweaks 03-25-2012 11:58 AM
a few more pics...
http://forums.pelicanparts.com/uploa...1332701847.jpg
http://forums.pelicanparts.com/uploa...1332701867.jpg
http://forums.pelicanparts.com/uploa...1332701882.jpg
wente 03-26-2012 10:24 AM
just a guess: it might go to the cabin air temperature sensor motor near the ash tray, which is around the same area where you are working. it gets power when the ignition key is on. though, I don't recall seeing anything with pins like that. it almost looks like it's been tugged out of a connector housing.
911 tweaks 03-26-2012 11:02 AM
Thx Ellsworth for your post...
Here is what I have checked & it does not appear to attach to any of the following:
fuel gage, oil gage, tach gage, sunroof switch, elect mirror cross over switch, headlite switch.
It reaches to the right side of the the car almost to cruise control decal on the knee pad...
**Does anyone know if this may attach to the ignition~key metal casting that has 1 of its ends plug into the steering column & the other end has the key tumblers...??
Does this car have a seatbelt or door open buzzer that may of been crudely attempted to be disabled...??
Any other ideas...??
Thx,Bob
LM3929 03-26-2012 11:04 AM
The two pin connector is off of the ignition buzzer
911 tweaks 03-26-2012 11:12 AM
Thx LM3929...it looks like I may need p/n 911 613 125 00...is this correct...?? If so, does it attach to the ignition/key casting...??
Thx, Bob
LM3929 03-26-2012 11:31 AM
Bob, yes that looks like the buzzer portion of the switch and yes it goes on the locking arm section of the ignition switch.
Lorne M.
86 911 Targa 03-26-2012 11:35 AM
Connector.
Correct, and well done!!!!
Here's the CKT/color codes from my factory manual.
And it does plug right in, but should be re-insulated
using the factory connector cover.
http://forums.pelicanparts.com/uploa...1332786897.jpg
911 tweaks 03-26-2012 12:54 PM
thx guys...part # above ordered from Pelican...I will document this all for future reference by others with pictures...
Bob
