-   -   Broken little stud - how to fix? (http://forums.pelicanparts.com/porsche-911-technical-forum/667771-broken-little-stud-how-fix.html)
Jerome74911S 03-25-2012 03:29 PM
I'm redoing the interior. When removing the bracket where the safety belt retractor resides, the small stud on the top broke off.
Is this a removable stud? Is there a nut welded on the other side? Do I have to drill it out and tap the hole? Is there material to tap into?
http://forums.pelicanparts.com/uploa...1332714483.jpg
http://forums.pelicanparts.com/uploa...1332714541.jpg
kerthunk 03-25-2012 04:35 PM
Isn't that just a bolt coming in from the wheel well side? I had the same issue and I THINK that I just took that bolt out and replaced it with a new one.
KNS 03-25-2012 04:56 PM
It looks like you've added some sound proofing to the rear quarters (and other places I assume) - how did that work out?
Jerome74911S 03-25-2012 06:07 PM
That could be, but I don't see how to reach the bolt if there's one in there. Plus, it is attached somehow. Welded in place?
Jerome74911S 03-25-2012 06:12 PM
I did install soundproofing, but I am just getting to putting the car back together (and addressing this broken bit and other details). Therefore, I don't know how the mass loaded vinyl/closed cell foam will work - or if the rear upholstered panels will fit over it.
drcoastline 03-25-2012 07:53 PM
Jerome,
I have a 74 Targa and at teh moment my interior is out including the seat belt bracket. On my car that is a stud not a bolt. I would grind the existing stud down and tack on a new one.
Jerome74911S 03-26-2012 03:21 PM
Thanks, that's the clue I needed - I didn't want to have to tear out the sound insulation to figure out what's back there.
Grinding on the agenda.
