DME Relay Change- now it won't start
1984 Porsche 911
Today I replaced my DME Relay, I turned the ignition and the engine started to turn briefly and then stopped.
Now nothing comes on when I turn the ignition, no power whatsoever. Like a fuse has blown but looking at the fuses under the front hood, I don't see any disconnected metal fuses.
Any idea of what could have been blown changing the dme relay?
Old 03-27-2012, 08:41 AM
Could be another bad DME.
Old 03-27-2012, 08:43 AM
Slippery Slope Victim
NY65912's Avatar
Probably bad out of the box.
I just had a new Porsche DME that was bad out of the box.
Mike²
1985 M491
Old 03-27-2012, 08:44 AM
Wine User
warner53's Avatar
I would suggest that you take your battery to your local parts store and have them load test it to see if it is any good.
Once you have the car cranking check for spark (pull a plug and ground it while cranking) then check for fuel.
Luck
Old 03-27-2012, 08:45 AM
Fuel tank is full, battery is brand new and it started this morning. Tried putting the old DME in and same problem- absolutely nothing, no crank, no power to anything...
Any other thoughts?
Old 03-27-2012, 08:53 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Relay.
Any other thoughts?
If it's a ÜRO relay, welcome to the club................
No longer carried by our host.
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 03-27-2012, 10:01 AM
NY65912's Avatar
Got to check each and every one. Mine was an Porsche not OEM (Kahler).
PS the Kahler works just fine.
Mike²
1985 M491
Old 03-27-2012, 10:18 AM
Tags
dme relay , starting problem
