Ride quality 86 Carrera
I just took my 86 out of winter storage. It came equipped from the factory with Bilstein shocks, it has 113,000 miles on it. The ride is very harsh almost violent over RR tracks and winter pot holes. My previous 911 was a 1980 SC with Koni's, it was no where near as firm as the 86. Any one out there have a Carrera with the factory Bilsteins? How would you describe the ride? Should I be be replacing mine do to wear?
Thanks,
Bernie P
Old 03-26-2012, 05:23 PM
I have a '86 with Boge shocks and just replaced them with new ones (68K miles). The ride is firm,but still comfortable. I know, not quite your question, but I thought I throw it in.
'86 Carrera Cabriolet Grand Prix White
'09 VW Beetle Convertible
‘24 Audi Q8 etron
Old 03-26-2012, 05:42 PM
my 86 is stiff as well, I'll be installing some coil overs to work with my torsion bars. Actually, I really don't mind the ride as it is right now, it corners very nicely and square.
Its easier asking dumb questions than fixing dumb mistakes
1974 Porsche 911 Coupe, RSR Project
1976 Porsche 911 Targa, Black
1986 Porsche 911 Carrera, Black
2006 Porsche Cayenne S, Black
Old 03-26-2012, 05:45 PM
Rescuer of old cars
Arne2's Avatar
My '84 Carrera coupe has the original green Bilsteins on it (listed as "SPORT SHOCK ABSORBERS" on the window sticker) with 155k miles. I'd call the ride firm and controlled, but not harsh.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 03-26-2012, 05:50 PM
My 86 has the bilsteins. Same here, firm but not harsh.
Mine had similar symptoms over pot holes and railroad tracks, a refurb of suspension bushings did the trick.
2007 Cayman
1986 Carrera coupe (sold)
1979 911 SC targa (sold)
Old 03-26-2012, 05:53 PM
Chain fence eating turbo
My '87 has torsion bars and coilovers; I'd call it VERY harsh!
Old 03-26-2012, 06:05 PM
You might want to check if they are the original shocks, maybe you have bilstein sport in the front?
My sc came with bilsteins. When they got old they were rattly and uncontrolled, not harsh just barbaric.
I upgraded to bilstein sports front and rear with stock torsion bars. They made the ride harsh in the front. Back seemed fine.
Old 03-26-2012, 06:29 PM
Dave Colangelo's Avatar
I have Bilsteins on my SC and its not as smooth as my 944 will coil overs but I have always found that rough ride to be part of that car I dont mind it. If you have the original shocks you may want to replace them, spring plate bushings as well, it will make things a lot smoother.
Regards
Dave
'78 911SC Targa (Back In Action!)
'00 996 Carrera (New kid on the block)
'87 944 (college DD - SOLD)
'88 924s (high school DD - Gone to a better home)
Old 03-26-2012, 07:37 PM
86FlatSix
JQ911's Avatar
Just acquired my 86 Carrera 6 days ago (my first Porsche). I noticed how stiff the ride was and it feels like the tires are kinda hard on bumps and RRs. Will check what type of shocks are installed.
I have Bilstein Sport Shocks on H&Rs with 2.5 drop on my Merc running on 245X35X19 but ride is not as hard as the Carrera. I guess I will have to get used to it but I am LOVING every second of it!
Old 03-26-2012, 07:51 PM
When my shocks needed replacing a few years back I went with Bilstein HD shocks front and rear not Sports. Couldn't be happier with the ride. A must if you want to use the car for road trips. I have the stock 16" wheels.
1986 Carrera Coupe Iris Blue
1990 Mercedes 190E 2.6 Smoke Silver
1986 Cadillac Fleetwood Brougham Chamois
Old 03-27-2012, 10:37 AM
Question to all, since I'm going to install rear coil overs should I go ahead and:
1. Remove my rear torsion bars
2. Leave them in and select lighter springs
If No. 2 is best advice, I have an 86 Carrera with standard 3.2L, what spring load is recommended. It is not a daily commuter, I'm looking for both smooth ride and performance. Opinions please and my mind is set on going with coil overs I just am undecided if I should remove my torsion bars or not. Thanks.
Old 03-27-2012, 11:07 AM
I was told that the Carrera shock towers will NOT support coilovers ONLY unless gussetted/reinforced.
On a side note, with the torsion bars (unknown size) and coilovers in my car, the rear virtually does not squat much at all. With the engine in or not, it seems to be only about an inch difference in height..........if that.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 03-27-2012, 11:26 AM
Dumb question, but what the heck...
Given that the car was in storage, are the tires inflated to "winter storage" pressure?
I have mine at 45-50 during storage, and 29/36 when I'm driving it. Big difference on ride quality.
1988 911 Carrera, M491 Cabriolet
2016 Cayenne
Old 03-27-2012, 12:39 PM
Bernie-P,
I have an 86 with Bilsteins on it. Previous to that I had an 83 SC cab. The ride was comparable on both when the road was smooth. The Carrera was a little harsher over the bumps but not much.
With 113k on it, if the bushings are original they are probably shot. Bad bushings can give you a harsh ride no matter what shock you are using.
John
'86 911 Coupe
Old 03-27-2012, 04:10 PM
Thanks for all the info. I am going to do the bushings and see if that improves things.
Bernie P
Old 03-27-2012, 05:57 PM
