Bill
Door Pocket Repair with Fiberglass
I am in the process of repairing the driver's door pocket on my 79SC. I have steamed and wetted down the pocket. It is now drying in wood clamps and ought to be straight once again. I thought I saw some references to fiberglassing the inside of the pocket to provide greater strength. Has anyone done this? How were your results? Any other ideas?
Thanks, in advance,
Bill
Old 03-20-2012, 09:44 AM
Yes I am wondering about this also. The place where the fasteners go thru the flange on the bottom of my otherwise nice pockets are broken making it difficult to mount.
Anyone done a fix on this kind of problem?
Thanks Richard
Old 03-20-2012, 11:28 AM
Bill
The mounting holes in my pockets were ripped out in a coupe of places so I rebuilt them with fiberglass and they seem to be fine. The fiberboard or whatever it is that the pockets are made out of soaks up the fiberglass resin pretty well, so the entire area seems stronger.
Old 03-20-2012, 11:36 AM
the best ones are made out of ABS like the newer 964's. I got some already covered from a guy in Florida who does mainly lincoln interiors. I think he advertised in Pano for awhile.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 03-20-2012, 01:11 PM
https://sites.google.com/site/911porschedoorpockets/home
1991 C2 Turbo
Old 03-20-2012, 01:14 PM
Garage Queen
PorscheGAL's Avatar
I repaired my door pockets with fiberglass on my 86 targa. I'm no fiberglass expert and it wasn't pretty at first. With new carpeting, the door panels look good to me and hold well.
Stephanie
'21 Model S Plaid, '21 Model 3 Performance '13 Focus ST,
Off to a new home: '16 Focus RS,'86 911 Targa 3.4, '87 930, '05 Lotus Elise, '19 Audi RS3,
Old 03-20-2012, 05:07 PM
I've used fiberglass to repair inside panels for British cars as well as Porsche and the repairs worked out well. I suggest you use 6 ounce fiberglass cloth (as opposed to the fiberglass matt) on both sides of the panel. If you want to reinforce the area around screw holes use thin washers. Stick them to the board before covering it with the cloth and resin. I like to use West System resin. It's a bit pricey but great quality and easy to use. You should be able to get all this at a local boat supply house. Good luck.
Old 03-21-2012, 06:25 PM
Bill
Many thanks. Great info and advice. Got my bearings and I'm ready to give it a try.
Bill
Old 03-24-2012, 11:58 AM
salukijac's Avatar
Originally Posted by RSTarga View Post
I just repaired mine with these brackets after seeing this thread. Good fit and pretty easy to do. You have to be careful when you peel back the carpet. In my case I was going to recover the pockets anyway.
A good fix for ~$83.
Jorge
1987 Black 3.4 911 Carrera Coupe
Old 03-26-2012, 06:30 PM
'73 911 T Targa
I repaired mine using West Epoxy also. West offers a variety of hardeners that can give extra time to work. Mine had holes cut for speakers which I replaced with pieces of masonite, just epoxied into the space. West also makes additives that let you turn epoxy into filler and fairing compounds. Even some carbon fiber tapes and stuff like that. I don't have a vested interest in West Systems, but I do like the strength and predictability of epoxy.
One note: Be careful mixing up large batches of epoxy. It generates heat when the epoxy and hardener react; the heat makes it cure faster which in turn generates more heat. I've read that large batches can actually catch fire. Also, once it starts to get hot, the cure accelerates and you're left with an unusable glob of goo. Spreading it out on a large surface after mixing helps.
Old 03-26-2012, 07:29 PM
nineball's Avatar
6oz cloth or mat may be too much for a beginner to work with. it takes some skill to get it right and 1.5oz is much easier to wet out. i usually tell people to start with a little 0.75oz to learn the techniques and gradually move up to heavier glass but no more than 1.5oz to start.
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 03-26-2012, 09:17 PM
