-   -   What is Wayne Building - Part 9... (http://forums.pelicanparts.com/porsche-911-technical-forum/668280-what-wayne-building-part-9-a.html)
Wayne 962 03-28-2012 01:45 AM
Here's something I thought of the other day while at the swapmeet in Anaheim. I need a new desk clock. I know that the old 911 and 356 clocks work using a coil that winds a spring-loaded clock every 45 seconds or so. This type of clock can be easily run on a battery. I've always liked the look of the 356 clock, so I found one and had it adjusted / repaired. Then I bought a 356 piston (I think it was $2). My buddy, Erich bead blasted it, and cut a hole in the center. Add the clock, a seal, some batteries, and a 356 / 550 4-cam connecting rod as the base, and you have a really neat desk clock!
-Wayne
http://forums.pelicanparts.com/uploa...1332924286.jpg
http://forums.pelicanparts.com/uploa...1332924298.jpg
http://forums.pelicanparts.com/uploa...1332924309.jpg
http://forums.pelicanparts.com/uploa...1332924320.jpg
http://forums.pelicanparts.com/uploa...1332924330.jpg
http://forums.pelicanparts.com/uploa...1332924339.jpg
OzGreg 03-28-2012 02:14 AM
Very nice!
Greg
Series900 03-28-2012 05:26 AM
I approve.SmileWavy
911lvr 03-28-2012 05:51 AM
very cool
Noah930 03-28-2012 05:58 AM
I'm sorry. Shouldn't this be on the 356 forum?
j/k Very cool desk clock.
HelmetHead 03-28-2012 07:20 AM
Awesome! I've got a couple of clocks and some old 3.3 pistons laying around...Hope you don't mind me copying your idea :D
Porsche Doc 03-28-2012 07:44 AM
Cool Man!
HawgRyder 03-28-2012 07:57 AM
Someone has too much time on their hands....LOL
Old pistons have been used for decades as pencil holders....ashtrays..and other wierd uses....but Wayne...I believe you have come up with a new one....Grats.
Bob
Wayne 962 03-28-2012 11:45 AM
I tried to find a 930 flat top piston, and I couldn't easily find one at the swap meet (none where I could buy just *one*). The 911 clock is a little bit bigger - I'm not sure if it would fit in the 3.3 piston, but it's worth a try. If you do use the 911 clock, then try to get the clock that runs with the little coil in the back. I'm not sure which year they made the change, but I believe that the battery life will be really good on this.
I like the 356 clock because it has twelve numbers, unlike the 911 and 912 green-faced clocks.
Thanks for all the kind words. On another note, the 935 full-sized model construction continues!
-Wayne
Rikao4 03-28-2012 11:52 AM
nice clock..
any info on / about the car modell.
Jagermeister... 1:18 ?
never seen one that large..
Rika
Paulporsche 03-31-2012 06:28 AM
Love it!
Wayne 962 03-31-2012 12:48 PM
That's a Jäger Tamiya 934 in 1/12th scale. Very cool model - they are available on eBay but they can be pretty darn pricey.
Wayne
