Carrera Chain Tensioners Oil Fed
Reading through Wayne's book and several threads regarding the priming of the Carrera Chain tensioner I have this question.
Once these are primed per Wayne's book then installed, the oil in the tensioner drips out. Does this defeat the point of pre-priming these before installation.
Once the oil drips out don't they just fill back up with air and? Help on this simple question is greatly appreciated.
Old 03-29-2012, 01:04 PM
When I did mine, I never had to prime them. But, that is only 1 datapoint.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 03-29-2012, 01:17 PM
Spiderman
Jesse16's Avatar
I never understood the point in priming myself. Pressure is pressure and whether oil or air, they'll push. Air is obviously thinner and will leak through leaving oil pressure at some point. If you get them apart, you'll see how stout all this mechanism is anyway and the amount of movement is miniscule. They don't just move back and forth with ease. I basically didn't touch my tensioners during my rebuild (they went in a plastic bag on disassembly and came back out for re-assy). Never a problem, they looked fine. I guess if they were "new", you could attempt to put oil in to start using a clamp or something. Unless you primed and held oil in all the hard and rubber feed lines, you've wasted your time. Still lots of air in the system.
Midnight Blue 08 Cayman S, Fun/Track
Black 12 VW-GTI, work
Mexico Blue 87 Carrera, sold, sad, not enough garage space.
Old 03-29-2012, 01:36 PM
Spiderman
Jesse16's Avatar
I think any air will simply leak through since the o-rings aren't designed to hold air pressure. All the air will push out naturally leaving oil only. Even that is better to leak through a little so all the air will gradually work its way out. Will still be good pressure.
Old 03-29-2012, 01:39 PM
