Importance of Leakdown and Compression Test in PPI
I'm getting a PPI done, and the company (European Performance in Raleigh, NC) doesn't do leakdown or compression tests by default, but I could request it.
The car I am looking at has a good history and a rebuild about 40K miles around 9 years back, done by a well-known pelican. How important is it to get leakdown and compression? I don't mind paying for it if its necessary, but saving money is always good - more funds for tools later. |
without compression and leakdown, you have no idea as to the actual health of the engine. even if its been rebuilt by a reputable person, things do go wrong. Worth the $'s
You mention saving money is good ... by doing a leakdown and compression test you could save yourself a LOT of money should the engine have any issues before you buy the car :)
Definitely a wise investment ! Cheers ! Phil |
what kind of PPI is that??
Hmm, I re-checked my handy PPI link and noted the following:
Yeah, other than a screwed up tub, a bad motor will have the biggest bite.
When I recently had a PPI done for a Carrera, the mechanic didn't think the leakdown was all that vital, because it doesn't tell you anything about worn valve guides, which is the weak link on the 3.2 motor.
I know Peter Zimmerman writes in his book that the leakdown is essential, but I wonder if compression check and an inspection of the valve guides does not give a sufficiently good sense of the overall health of the motor? How much extra does a leakdown add to the PPI? |
leakdown tests don't tell you if the guides are worn, but they show the results of worn guides, ie: worn valve seats. valves tend to be thrown onto one side of the seat when the the guides are sloppy, which wears that area more than the rest of the seat, so, out of round/eccentric seat plus round valve = higher leakdown results. 911s don't burn valves much at all. the seats wear out instead.
Get both leakdown and compression tests. JW and others have often mentioned why, as they test different things, actually.
Any mechanic who knows these cars, knows that (period). Best, Doyle |
| All times are GMT -8. The time now is 11:23 AM. |
