Importance of Leakdown and Compression Test in PPI
I'm getting a PPI done, and the company (European Performance in Raleigh, NC) doesn't do leakdown or compression tests by default, but I could request it.
The car I am looking at has a good history and a rebuild about 40K miles around 9 years back, done by a well-known pelican. How important is it to get leakdown and compression? I don't mind paying for it if its necessary, but saving money is always good - more funds for tools later. |
without compression and leakdown, you have no idea as to the actual health of the engine. even if its been rebuilt by a reputable person, things do go wrong. Worth the $'s
Northern Motorhead
You mention saving money is good ... by doing a leakdown and compression test you could save yourself a LOT of money should the engine have any issues before you buy the car
![]() Definitely a wise investment ! Cheers ! Phil
Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 |
what kind of PPI is that??
Hmm, I re-checked my handy PPI link and noted the following:
Chain fence eating turbo
I LOL'd. What is the point of NOT doing them in a PPI? Those are the most important checks and if not done will probably cost the most money if there is an issue.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
Mo money = mo parts
Yeah, other than a screwed up tub, a bad motor will have the biggest bite.
Greg 86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten 65 Ducati Monza 250 & 66 Monza Junior (project) "if you are lucky enough to own a Porsche, you are lucky enough" |
When I recently had a PPI done for a Carrera, the mechanic didn't think the leakdown was all that vital, because it doesn't tell you anything about worn valve guides, which is the weak link on the 3.2 motor.
I know Peter Zimmerman writes in his book that the leakdown is essential, but I wonder if compression check and an inspection of the valve guides does not give a sufficiently good sense of the overall health of the motor? How much extra does a leakdown add to the PPI? |
Friend of Warren
I would get another mechanic.
Kurt V No more Porsches, but a revolving number of motorcycles. |
<insert witty title here>
Maybe $1-200? It's a no-brainer, IMO. Most PPIs I've had done run $250-400, including compression and leakdown. I can't imagine doing otherwise on a 20+ year old engine.
Current: 1987 911 cabrio Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster |
leakdown tests don't tell you if the guides are worn, but they show the results of worn guides, ie: worn valve seats. valves tend to be thrown onto one side of the seat when the the guides are sloppy, which wears that area more than the rest of the seat, so, out of round/eccentric seat plus round valve = higher leakdown results. 911s don't burn valves much at all. the seats wear out instead.
Get both leakdown and compression tests. JW and others have often mentioned why, as they test different things, actually.
Any mechanic who knows these cars, knows that (period). Best, Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
