Is there a best way to powder coat an oil tank?
I'm going to get some stuff powder coated and was wondering about the oil tank. Thanks for any ideas.
Dean |
AutoBahned
you can get a special coating used that is claimed to disperse heat better, but I doubt it is important
They will sandblast the tank before powder coating, make sure you get every grain of sand out of the tank before use. I would use paint to avoid this possibility, engines are not fond of sand in the oil at all!
River Rat
I would remove it from the car first.
1986 930 - K27-7200, Andial Intercooler, Tial Wastegate, Electronic Boost Controller, B&B headers, Bodart Zork, Leask Adjustable WUR, Full Elephant Racing Suspension w/Adustable Spring Plates and Von Shocks, Wevo Transmission Mounts, Fuel Safe Fuel Cell, Forgelines (9"/11"), Hargett Shifter, Innovate AFR, Cobra CF Seats, DAS Rollbar, Coleman Floating Rotors, Lightweight Interior, Forgeline 17" x 9"/11", 2800 lbs. |
This is my main concern. I'm just looking for advice. Thanks.
Why powder coat? I had to take out my tank for a leak repair and ended up giving it two coats of POR 15 I had on hand. Beautiful finish and I know it will last. You can only see the tank from the bottom anyways..................Isn't powder coating a bit on the pricey side these days?
![]() Bob 73.5T |
Fleabit peanut monkey
Sunroof has a point. I powder coated mine but to what end? I was having other parts done so thought why not.
I took mine to a radiator shop and had it dipped. It stripped off the paint and cleaned it out. Plus it provides assurance to the shop that the tank is clean inside before they cook the powder on. I sealed it off myself (after dipping) and sandblasted the rust spots and then the shop puts special tape on the openings/filter mount area. See my tank - post #2 Oil tank restoration? A better method may be to seal and sandblast spots first then take it to the dip shop to make sure it is completely dirt and sand free before coating. Depends on how confident you are keeping the sand out. I still flushed out the tank with kerosene after it was all done. |
AutoBahned
powder coating is much more durable than paint -- the oil tank is in a heavy grit & stone blast area behind the wheel
[QUOTE=Bob Kontak;6652314]Sunroof has a point. I powder coated mine but to what end? I was having other parts done so thought why not.
I took mine to a radiator shop and had it dipped. It stripped off the paint and cleaned it out. Plus it provides assurance to the shop that the tank is clean inside before they cook the powder on. I sealed it off myself (after dipping) and sandblasted the rust spots and then the shop puts special tape on the openings/filter mount area. See my tank - post #2 Oil tank restoration? A better method may be to seal and sandblast spots first then take it to the dip shop to make sure it is completely dirt and sand free before coating. Depends on how confident you are keeping the sand out. I still flushed out the tank with kerosene after it was all done.[/QUOTE Thanks for the info. Like you, I'm having some other things done and figured I'd do it also. Dean |
Always learning
I would highly advise against sand blasting your oil tank. The grit / engine risk is to high.
Why don't you just use a wire wheel with POR high temp paint? Cheers |
AutoBahned
or try soda blasting
why remove old paint? do you look at the oil tank much? if rusted, then remove flakes & use a rust converter aka rust reducer |
