ayd ayd is offline
Cigarette lighter outlet
My plugs for GPS and phone do not make firm contact with the cigarette outlet in my 87 911. Seems like the outlet is slightly too big. Does anyone have ideas how to
correct it.
Old 03-28-2012, 06:17 PM
MH911's Avatar
Several threads on this subject. Here's a good one.
Dr. Bulczynski 3.2 Cigarette Lighter MOD $5.99
Kipp
1987 Black 911 3.2 Carrera Coupe
1999 Green Mazda MX5 (SOLD)
Old 03-28-2012, 06:25 PM
ROW '78 911 Targa
timmy2's Avatar
Or, do what I did and buy a rectangular 3- 4 outlet adapter with usb from flea bay for the same price. The side contact prongs on the one I picked up fit the larger diameter lighter outlet. I can plug in multiple devices too. I used a 3"x1" stip of self adhesive velcro to mount under my ashtray. Easy to remove and put in glovebox. (no console in my car, but would work in there just as well and be hidden too if placed well).
This one:
http://www.ebay.com/itm/Triple-Socket-12-24-Volt-DC-Car-Adapter-Power-Outlet-w-USB-Port-Black-Silver-New-/230756714782?pt=PDA_Accessories&hash=item35ba2c091e
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 03-28-2012, 06:33 PM
cain's Avatar
You can also try looking under the passenger seat and if there is an old blauplunkt amp under there that is not being used and forgot about, pull it and use the Positive and the ground that is there for 1 of those quad adapters and wire it in with a switch so you can kill the power, the amp was always hot and is fused at the fuse block, below the block, if your car came with an amp.
Old 03-28-2012, 08:20 PM
80-911SC's Avatar
Or you can bow out the ears on the plug to your GPS and they should make contact ..
You can find " euro " adapters around also .. basically a sleeve that slide in and takes you from the slightly larger euro to the standard .. I got a used lighter housing out of one of my old cars and cut it up to make a sleeve .. just watch the bottom that you don't connect the center + to the outer piece - ...
Old 03-28-2012, 08:46 PM
Just install a seperate power outlet under the dash. cheap and easy.
Old 03-30-2012, 07:48 PM
81% stable 67% of time
Mister Moo's Avatar
I wrap pipecleaners around my plugs. Just right.
Best regards, Mister Moo
'87 Carrera Targa
'07 BMW R1200R
Old 03-31-2012, 12:15 PM
A guy I know wrapped the plugum with masking tape to get the right tightness. He says it's worked fine for many years. Ah yes, it's an '87 too.
Ned Nyna 11
87 Carrera Targa
98 528i BMW
2004 Jetta 1.8T
Old 03-31-2012, 12:52 PM
