EFI conversion kits---Suggestions
I want to convert to EFI and Im looking for a complete kit....Give me a shout on your opionion of the best conversion kits...im talking complete kit. 1970 911 T
Old 03-30-2012, 01:36 PM
I would rather be driving
jpnovak's Avatar
If original engine and induction...
Why do you want to convert away from carbs? Zenith's run great in a 70T.
I think Clewett is the only one that offers a PMO ITB/EFI kit.
You might also check Rennsport and Rothsport for their offerings. I know both have EFI throttle bodies and are capable of assembling an engine but am unsure of "kit" availability.
Al Iksomal on the board has a kit based on Triumph triple throttle bodies. You should contact him as well.
If you had a CIS engine I would recommend the Bitz Racing kit. Easy to install and very complete.
Old 03-30-2012, 02:57 PM
al lkosmal's Avatar
Thanks for the mention Jamie................
RenC.....check out my kit at
DZ X-Factory ITB Setup
If you have any questions, please feel free to contact me: PM me or email :
koz@x-faktory.com
regards,
Al
RGruppe #669
http://www.x-faktory.com/
Old 03-30-2012, 05:45 PM
I have done 2 70/71 911Ts and this is my writeup.
Another ITB Megasquirt and EDIS setup experience
If you are going to buy a "kit" start with the PMO throttle, manifolds and linkage. Then add EDIS and megasquirt. The DZ X and T-Bitz kits are still missing ignition and if you don't get rid of the Marelli dizzy you are wasting your time.
Last tip, check your car for a return fuel line. If it doesn't have one a stainless one like the factory did, it can be installed in 3 simple steps.
1.Disassemble entire car.
2.Insert return fuel line through tunnel.
3.Reassemble entire car.
Someone correct me if I missed a step there ;-)
Kevin
2000 Boxster S
2013 Golf R
1999 911 C2 Aero
Old 03-30-2012, 06:14 PM
Al
What did you come up with for filters... I have yet to see anything about that either here or dzug.
Old 03-30-2012, 09:36 PM
al lkosmal's Avatar
Originally Posted by jtosburn View Post
Al
Although this pic is from a different EFI setup than the Speed Triple kit (proto in progress) it shows the Uni-filters that are part of the kit.
regards,
al
RGruppe #669
Old 03-30-2012, 09:44 PM
al lkosmal's Avatar
[QUOTE=quaz;6657873]I have done 2 70/71 911Ts and this is my writeup.
__________________________________________________ __________________________________________________ ____
These are all good choices....................but....................
I would recommend that you start with standard ignition and dial in the fuel/injection control. Once you get that dialed in properly, move on to ignition control. Crankfire, using EDIS (inexpensive, bulletproof and fairly straightforward addition to all of the "kits") is a good choice and the M'squirt will control both. Tuning is really not that difficult.....but .......................... changing one major engine control variable at a time is good practice, typically.
regards,
al
PS: that's just me..............I am easily confused and i could be wrong.
RGruppe #669
Old 03-30-2012, 09:56 PM
I should qualify my statement above. I agree with Al in that if you do not have a lot of patience and a strong engineering background you need to start simple and then add a system at a time. Trouble shooting a car that was once running and now is not, but you have changed everything can drive you a bit insane. However the weak point on the older cars is the ignition and without it you will never get 100% out of EFI. Do the injection with whatever kit you choose, get it running and then ditch the dizzy. Good plan of attack.
BTW Al those throttles look nice!
Kevin
Kevin
2000 Boxster S
2013 Golf R
1999 911 C2 Aero
Old 03-31-2012, 02:06 AM
Tags
efi conversion kits
