voltage meter readings
I purchased a voltage meter for the cigarette lighter to see what the readings would be while driving:
idle and no electrical consumers: 13.7-14.0 idle with headlights/fog lights/heater blower: 13.2-13.4 2000 rpm and no electrical consumers: 13.8-14.2 2000 rpm with headlights/fog lights/heater blower: 13.1-13.4 Do these readings seem appropriate to a healthy alternator and voltage regulator?
"Charlie don't surf!" |
Formerly known as Syzygy
In my experience, yes. Your 14+ volts measurement may be on the high end, but acceptable IMO.
When my VR went, I was getting about the same measurements, but half way down the block it jumped to 16v, so do a bit of a drive around if you suspect something may be amiss.
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
John W
Charging spec. is 13.6 to 14.2 so you're right on.
----------------------------------- John 89 3.2 Targa 123k miles |
looks good. I'd advise getting a voltage reading AT the battery terminals just to compare to the cig lighter point..correlate the two. In fact, I'd make use of the SAME meter via clip leads when testing AT the battery terminals.
Best! Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
