-   -   Ditzy Dizzy (http://forums.pelicanparts.com/porsche-911-technical-forum/66898-ditzy-dizzy.html)
J P Stein 04-27-2002 04:08 PM
Ditzy Dizzy
I get a clicking noise from my newly installed RS distributor.
It rises and falls with rpm up about 1100 when it disappears.
I can also make it stop by pinching off the vacuum line.
I can feel it when I put my hand on the Vacuum advance housing.
I'm begining to think that disconnecting the line and plugging it off
wouldn't be a bad idea.
Can't find anyhing that's making contact, now. The rotor was touching the Pertronics unit, so I changed it out for a non rev limit unit and that clears....."that ougha do it", I sez......NOT.
I'm stumped.
john walker's workshop 04-27-2002 04:15 PM
it's probably a retard anyway, so you don't need it. if the vacuum hose is attached to just one or two intake ports, it will pulsate. try setting the total advance to 35° and plug the vacuum ports. if it pings, set it back a couple of degrees from there.
RoninLB 04-27-2002 04:24 PM
I have done what JW writes about last month in a 2.7 '77 CIS[stock] w/early Carrera dizzy...no problems, starts great cold, very cold, warm, hot, and runs fine..the RS pistons are 8.5 ..........Ron
J P Stein 04-27-2002 08:35 PM
Yup.....hooked up to one port. That's gotta be it.....thanks, John.
I didn't like that vacuum line nohow.
