2porscheguy's Avatar
Short shift upgrade...which kit do you recommend?
Dear Fellow Pelicanites!:
I have a 1980 911SC Targa and I am considering performing the short shift upgrade sometime this fall/winter. I am quite certain that there are numerous threads on this topic but...which kit would you recommend? I understand that there are basically 4 kits available (as listed by our host)....the Porsche Factory Kit, the Weltmeister Kit, Wevo, and Rennshift Jwest......by all means, do please inform me!
Sincerely,
Alex
Old 11-01-2011, 12:29 PM
I'd go with either the Factory Kit or the Wevo depending on your budget and how drastic you want to go.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 11-01-2011, 01:18 PM
i have a wevo and it sucks ,not saying they all do just the one i have . good luck .
Old 11-01-2011, 01:19 PM
ivangene's Avatar
factory
Ed M
86' Coupe
Old 11-01-2011, 02:00 PM
Oh Haha's Avatar
If budget is of no concern, the Hargett is the way to go. Next in line would be the WEVO.
The factory is the best bang for the buck, IMO.
The Weltmeister is ok but it's on the low end for a reason.
Be sure to check/replace all of the bushings associated with the shifter and linkage to get the most out of whichever version you choose.
Pacific Blue
Wayne
Old 11-01-2011, 03:19 PM
trak ratt's Avatar
Factory '86 "kit"
Have used one for years on my '82 and now the '84. Very pleased with the way it has worked.
Old 11-01-2011, 03:24 PM
I have the Factory SS in my track car and I am happy with it. Make sure you also do all of your bushings, front and rear to get the most out of the upgrade.
That said, if you have money burning a hold in your pocket, go Wevo.
'02 6GT2 - Weekend toy
'04 6GT3 - Track weapon
'13 Cayenne GTS - Daily duty
'77 Yamaha RD 400 - Wheelie machine
Old 11-01-2011, 03:32 PM
fifftyninevwcab, what "sucks" about your Wevo short shifter?.....just curious...
Alex
Old 11-01-2011, 07:16 PM
If you think the WEVO is bad.........well my guess is your bushings, coupler and maybe even trans need fixing.
I have the factory shifter with new bushings and wevo coupler. Have enjoyed it for 6 years or so......and the trans is good as well.
I had the weltmeister and was glad to get rid of it. The design is not as good as the factory short kit.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 11-01-2011, 08:57 PM
RETIRED
Joe Bob's Avatar
Love my WEVO....but the rest of the linkage needs to be in good shape.
2012 ML350 3.0 Turbo Diesel
Old 11-01-2011, 09:32 PM
user & abuser
love my WEVO
vini vidi vici
Old 11-01-2011, 09:50 PM
I use the factory short shifter. However, in defense of the Weltmeister unit, the most common user complaint has been the increased effort required to shift - bordering on uncomfortable notchiness. This is due to the very short shift lever which I suppose they designed to further reduce the shift throws (34% versus 24% for the factory SS). An arm with a 36" sleeve length is also required.
A shift lever extension makes the WM unit much more usable:
Unmodified versus modified Weltmeister Short Shifter:
Installing a 5.5" lever extension does a couple of things:
1. Reduces the effort required to shift
2. Brings the shift knob closer to the driver and steering wheel
I've added a similar 3" extension to my factory short shifter and the net difference between the two units is nil. In addition, shifting effort with both short shifters now feels no different than a standard shifter.
The caveat is that extending the lever loses some reduction in shift throw distance. However, IMHO, the more convenient shift knob location and reduction in shifting effort makes this modification worthwhile.
A link to more discussion:
Yet Another Shifter Thing
Sherwood
Old 11-01-2011, 10:17 PM
Walt Fricke's Avatar
I like the factory short shifter with the Seine Systems alteration to spring load it in the 3/4 plane (as the Factory finally started doing on its products way later than I think it should have).
The factory SS shortens the front to back throw, but not the side to side. Having to move your hand the old distance right to left to select the plane you want is helpful, as missed shifts are a result of not being in the desired plane, not a result of any fore and aft motion.
Old 11-02-2011, 12:13 AM
Racer
winders's Avatar
How does the factory short shift manage this? You are saying the lever ratio is changed fore and aft but not side to side. How?
Scott
Old 11-02-2011, 12:55 AM
ivangene's Avatar
yippy...a shift tower show and tell....
here is mine: home made
as for the complaint about the wevo, I am working on the side to help him out. as far as I can tell from our conversations he has a wevo coupler and a stock shifter....we are working thru it thru emails
Ed M
86' Coupe
Old 11-02-2011, 05:30 AM
LJ851's Avatar
Very nice, Ed. Do you have an extra kit you want to sell me?
Old 11-02-2011, 07:21 AM
ivangene's Avatar
I have most of it (the spring and longer pin) ready
the "gate" and tab are not ready, they are 304 SS and a PITA to cut, if someone was to get excited I could make one
the "kit" is pretty involved to install...I notch out the side of the housing to allow the long pin out the side and drill 2 holes for the spring, while its apart I work on the factory parts to smooth out the operation.....there is no money in this because Seine does it already but i sell the parts for about $100 if you are interested
(sold 4 already locally where I did the install )
my email is my ID name @ msn dot com
Ed M
86' Coupe
Old 11-02-2011, 07:29 AM
LJ851's Avatar
I'm excited. Sent you an email.
Old 11-02-2011, 07:46 AM
Sherwood
From the man who know this best there is simply not an Idea out there that for the money makes the a 911 Porsche shift better than the Seine SHifter gate. Then add the 2 inch extension and nothing feels better either! I am glad you picked up the ball and now everyone can easily get the 2 items needed to not miss a shift (SInce I installed my Seine) and no effort at all to shift. The added throw also makes the Shift gate a little wider which also makes it harder to miss a shift!
Made History at Daytona and Still one Fast Old Man! 1982 Porsche 911 SC & 2017 Honda Si
Old 11-02-2011, 11:11 AM
Gentlemen, thanks a bunch for your information on this topic....all input is much appreciated!
Does anybody have any experience with the Jwest Rennshift kit?....haven't heard Boo on that install!
Old 11-02-2011, 12:16 PM
