Can someone explain "UnSprung Weight" for dummies
I was at an auto-x this weekend and at the track was an old Jaguar on jackstands. I was pointing out to my friend that the rear rotors are inboard and near the differential. Then I heard someone mention that those rotors were a great benefit for "unsprung weight".
I'm just wondering how this works - mostly for my own curiosity. |
Unsprung weight is all weight from components that are Not mounted to places that are attached to the suspension springs. The benefit is that the suspension is not moving as much weight so it reacts faster and with less energy to try to keep it oscillating. Example: Batteriies, steering rack, engine are all unsprung (not attached to the end of the springs); Wheels, tires, brakes are sprung weight, they are attached to the end of the spring.
Unsprung Weight.
Unsprung mass - Wikipedia, the free encyclopedia |
Other way around. |
ooops... i did that backward. dammit, been a long day.
No one has it quite right yet.
On the car, some weight is unsprung, some is sprung, and some is some proportion of both. Here is what Fred Puhn has to say: "The chassis supports the engine, body and occupants. It rests on springs which insulate the chassis from the road irregularities, and from the driver's point of view the chassis bounces up and down on the springs. The weight of the chassis and all parts mounted on the chassis is considered to be sprung weight. The tires, wheels and suspension parts that move up and down with the wheels are effectively underneath the springs and are not insulated from bumps in the road by the cushioning effect of the springs. The moving suspension parts are considered unsprung weight. Some parts are attached to the frame at one end and to the wheel at the other. The frame end is sprung and the wheel end is unsprung." "Some parts" include axles, control arms, springs, and shocks. Axles and control arms would be 50% sprung and unsprung. Shocks and springs are different. For a shock, the weight of the parts that don't move with the wheel are sprung. Scott |
Nice.
Now for us super dummies.. Why does it matter? how does it impact handling? is it more theoretical or can you really tell the difference when driving? |
Think of inertia. The less mass in the moving suspension components the easier time the shock and spring will have keeping the tire in contact with the road-and that is what the suspension is for after all.
Edit-this includes the brakes/wheel as well of course. |
Easiest thing to do is to make sure your wheels are as light as possible. The difference between a Fuchs forged alloy wheel and just about any other standard cast wheel is significant - and this translates into more unsprung mass. Drilling your brake rotors could also help, although I think this is usually done to improve heat dispersal. The Jag's inboard brake rotors in effect took all the rotor mass and turned it into sprung weight (well, at least a portion of it anyways). Yes, you can feel the difference in handling when there is less unsprung weight. It's actually pretty amazing. Less unsprung weight will show up in a few ways: 1. the suspension's ability to absorb bumps and settle down quickly is reduced the more unsprung weight there is. this means that if the car suspension has to deal with a bump and is unsettled during a corner entry, or mid corner, it won't be as compliant and you will not be able to go as fast as you could with more compliant suspension. 2. less unsprung weight = quicker direction change. The greater the rotating mass of a wheel the greater its gyroscopic effect, which is what keeps it wanting to continue going in a straight line. Reducing the rotating mass makes it easier to turn, making for 'better handling', lighter steering, quicker direction changes. There are probably some other variables that unsprung weight affects as well like how hard your suspension has to work, and therefore how long it will last. And how much heat it will generate, which effects how well it works. These are secondary, imho. So-called 'mag' wheels were a big deal back in the day because they were made of magnesium alloy which was significantly lighter than the then-standard steel wheels. I don't know if carbon fiber is being used for car wheels - it is for motorcycles. It takes unsprung weight to the next level. |
http://3.bp.blogspot.com/-gMubM-EjjX...0/DSC_6425.JPG As seen here: danumatic: Dymag carbon fiber wheels |
I read that some auto racing groups had outlawed or frowned upon the use of carbon fibre wheels. I guess when they get damaged, they fracture badly it's often with quite catastrophic results. Or maybe I misunderstood.
I know they are used in motorcycles regularly. In this, having less unsprung weight is quite important. A race bike weight of 350 lbs isn't abnormal, so even saving a few ounces makes a difference in top levels of racing. |
There are aftermarket full carbon fiber motorcycle wheels (not just rims, they are monoblock, hollow spoke). I think they are made in South Africa. There was an article in Sport Rider a while back.
BTW, the Formula SAE team used carbon fiber wheels for a bit. They ended up breaking and they are now back to minilites. |
For those that might get confused, he is talking about the student race team at his college, not a professional Formula racing team.
One big effect I did nod red yet:
The less rotating mass, the less energy needed to accelerate/brake. This effect you can really feel on a motorcycle with lighter wheels or on a bicycle. |
http://www.hostbest.net/3.jpg |
The mass of the wheels, rotors, and the axles (50%) do take a 'triple hit' as they are unsprung weight, they need to be spun up to get them moving, and they need to be accelerated forward like the normal dead weight of the car. ------ To really get a clear mental picture of the importance of unsprung weight a good mental exercise is to imagine the cornering interaction of the suspension with a washboarded road. Most everyone has had the experiance going around a hairpin corner on a gravel road where it is heavily washboarded. You notice that the car just doesn't want to corner right after you notice that all your fillings just fell out... We talk about slip angle a lot and it is pretty obvious that if you push sideways with a great quantity of force then the rubber carcass of the tire is going to flex. The opposite is true too. Unless the tire is flexed then it isn't going to generate the cornering force. As you go between the ridges of the washboarding the flex of the tire is going to relax. When it hits the next ridge it isn't going to create cornering force until the tire gets flexed again. Say for example that your tire is flexed about 1/2" when it is creating your maximum cornering force on this surface... That means that once the tire comes in contact with the next ridge it still isn't going to create its maximum force until it moves another 1/2" laterally. In other words each time the tire becomes unstuck you have a double whammy from at first not being in contact and second from waiting for the cornering force creating flex to build back up. If you had a magical suspension where the moving parts had zero mass the tire would be able to follow the contours of the ground exactly so the preloaded flex of the tire would be constant and you would get a similar cornering force on a rough surface as you would get on a perfectly smooth road. (Computerized "active suspensions" basically attempt to replicate this by trying to force the tire to exactly follow the contours of the road.) One of the details of why unsprung is so important has to do with how a conventionally suspended car performs in practice. Say you have a reasonably smooth road and a car with a nice low unsprung weight and a good suspension that keeps the force pressed on the contact patch in the range of 95% to 105% of the cars weight. Look back at the interaction of the tire with the washboarded road. The same thing will happen here but what you will see is that when you get to a 95% loaded moment your slip angle will release so you are generating 95% cornering. The gotcha is when you hit a compression a 105% downward pressure you don't get 105% cornering. You have to wait till the slip angle builds again. The end result is you won't get more then the 95% cornering of your lower adhesion limit. Think about all this the next time you think about putting Big Reds on your early car that has never had its brakes get near to overheating. :D |
Well I thought about that, but thought to keep it simple...
However: Less unsprung mass that is rotating too will lead to best results;) |
To further demonstrate the effectiveness of unsprung weight. In Excellence magazine, Manthey Racing had released an upgrade package for GT3's and they tested it. Unlike their competitors, who concentrated on upping the HP and putting lighter weight body panels on the car, Manthey Racing concentrated on building lighter suspension components and worked with BBS to develop a be-spoke wheel package. Olaf Manthey said they concentrated on reducing unsprung weight because in testing he believes that reducing 1lb of unsprung weight is the same as reducing 7lb of sprung weight.
The 50% thing is just an engineering shortcut factor. To get exact answers you need special programs- ADAMS I believe- which do multi-body dynamics. It is very hard to model all of those individual pieces interacting with each other as they move without a computer. The systems are coupled. It is much easier when you "fix" or "ground" a link like the wheel- constrain it to remain on the ground. Then you can just use energy methods to come up with an equivalent inertia for a 1 degree of freedom quarter-car model. This would take into account an equivalent quarter car sprung mass weight as well as the inertia of the suspension links. If you go 2DOF on the quarter car model then you model the tire as a spring and things get more complicated with a coupled 2DOF system. Add the 3 other corners and I believe you end up with a 8 DOF model. A car with wheels grounded has 4 DOF- heave, roll, pitch, warp. The excitation can be several things- one wheel bump or roll being common.
I have the basic skills to solve a problem like that, but I would need to know the inertia properties of the sprung mass most importantly and also of the suspension and wheels. |
To paraphrase Colin Chapman (I think) : To go faster, add lightness ;)
Yeah, the bottom line is less is more when it comes to unsprung weight. The hard part is knowing when adding some sprung mass is worth the reduction in unsprung mass. This would happen when using inboard brakes on the front wheels of a rear wheel drive car, as was seen in F1 years ago.
The RATIO of sprung to unsprung weight is the critical factor. If you strip a car down by removing the interior trim and fitting lightweight fenders, for instance, and then fit heavy wide wheels/tires with big (heavy) brakes you have effected this ratio negatively.
Thank you for the education. I love this place.
When you look at a land barge you will see that they have a small percentage of unsprung weight. They just left out the part about "adding lightness" that is so important in a sporty car. |
Yeah, but...
Unsprung weight is important but not overwhelmingly so. Camber change matters, too, as it maintains maximum tire contact with the road surface. Some sports cars (old Alfas, for example) have straight rear axles that weigh a lot but keep the wheels straight upright in corners, minimizing camber change, so the tires stay in better contact with the road. Larger wheels and tires can be heavier (more unsprung weight) but provide better traction, too. Like many other aspects of automotive engineering, suspension design involves compromise. Frank |
As long as the road surface is relatively smooth-and most race tracks, and some public roads are. But, introduce roughness into that road surface and low unsprung weight comes to the fore. Which may have contributed to the Porsches beating the Alfas in the TransAm...
Ferinstance...:) |
It's why I get frustrated that there isn't a large selection of good 15" tires. The reduction in unsprung weight by swapping out my 16's for equivalent sized 15's is significant. I'd keep the same width and aspect ratio too, so it wouldn't be a compromise.
Wheels have been mentioned, but I would point out tires matter too... There is a HUGE variation in tire weights out there, is similar sizes... Some folks spend $$$ getting lighter wheels or lightweight calipers, only to unsuspectingly slap on a set of tires tire that is 20 lbs heavier than it could be. Tire rack has weights listed under "specs", it's shocking at times...
For instance the michelin supersport in Cayman S rear size (265) is 4 lbs lighter per tire than a bridgestone Re11.... you WILL feel that... |
The best contrast between low and high unsprung weight would be a rally car 911 with Fuch wheels and street tires on it. Handling, good.
Take them off, put a 12" lift kit on the 911 and mount some 33" tall mud tires and 20" rims on it. Would you notice a difference in ride quality and performance? Yes. Brake rotors too. Everyone wants the biggest they can fit within a rim but the weight increase is a penalty. |
