Send a message via AIM to NoLift911
Need for Relay Panel/Fuse block in engine compartment with no HVAC?
84 Carrera - removed all HVAC. From what I can tell via the wiring diagram there are two relays for heat, don't need them and 3 fuses for heat/A/C blowers...don't need them.
There is the 14 PIN connector that also is combined into this relay panel that hooks up with the engine harness, so I don't want to screw anything up there.
I have traced everything and I just don't see the need for the panel - Just want to be sure I am not missing anything, anyone else done this with their race car?
Thanks -
Jeff
Old 04-03-2012, 08:24 AM
porsher
aston@ultrasw.c's Avatar
I removed the panel, relays and fuses from my 86.
Nothing bad happened.
I did retain the socket for the idle b-c jumper.
I also made a simple bracket to support the engine harness connector.
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
Old 04-03-2012, 12:14 PM
OK thanks - good to know. I was going to keep the black socket also - forgot about the jumper for the idle adjust (SW chip) but yes I am keeping that and will just tie it out of the way.
Bracket for the engine harness is a good idea.
Jeff
Old 04-03-2012, 12:25 PM
