-   -   Is there a way to measure RPM (other than your tach)? (http://forums.pelicanparts.com/porsche-911-technical-forum/670095-there-way-measure-rpm-other-than-your-tach.html)
Tidybuoy 04-06-2012 02:23 PM
I'm wondering if there is a way to measure my RPM other than the tach.
I'm asking because my tach reads about 500-600 rpm at idle and that seems fine, if not a little high. I can't imagine pushing it up to 850-900 as that would seem really high.
So, I'm wondering how accurate my tach is - I'm not an electrical wizzard but I do own a multi-meter. Is there a way to test with that?
tazzieman 04-06-2012 02:56 PM
Indeed. e.g. Timing Lights
What are your circumstances?
Targalid 04-06-2012 02:57 PM
Optical tach. Sold at Harbor Freight for about $40. Point it at the pulley and read the rpm.
Carl83911 04-06-2012 03:25 PM
tach/dwell meter
Tidybuoy 04-06-2012 04:16 PM
Hmmm, I have a timing light but it only flashes. I don't think it has any guage and I don't have a tach/dwell meter - but, I know someone who has one.
Thanks.
80-911SC 04-06-2012 05:06 PM
Look around for a tach / dwell engine diagnostic .. they can be found on ebay for not to much ... also you could hook up another tach and check it vs yours .. easy if you have some one around with a Porsche and a compatible tach ... or if you could wire in an aftermarket tach in temporarily ...
DRACO A5OG 04-06-2012 08:45 PM
my LM2 has a Tach feature
There are some DVM that registers tachs as well.
cashman 04-06-2012 09:03 PM
My DVM purchased from AZ plugs into the coil and gives you a digital reading.
dshepp806 04-07-2012 03:09 AM
My meter gets it off of the coil, as well.
Doyle
