Is there a way to measure RPM (other than your tach)?
I'm wondering if there is a way to measure my RPM other than the tach.
I'm asking because my tach reads about 500-600 rpm at idle and that seems fine, if not a little high. I can't imagine pushing it up to 850-900 as that would seem really high.
So, I'm wondering how accurate my tach is - I'm not an electrical wizzard but I do own a multi-meter. Is there a way to test with that?
Old 04-06-2012, 02:23 PM
tazzieman's Avatar
Indeed. e.g. Timing Lights
What are your circumstances?
'81 924 , '85 944 , '78 911SC , '82 928 5.0L
"They run best being run close to the ‘limit’ and done so regularly" - Grady
Old 04-06-2012, 02:56 PM
76 911S Targa
Optical tach. Sold at Harbor Freight for about $40. Point it at the pulley and read the rpm.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 04-06-2012, 02:57 PM
Carl83911's Avatar
tach/dwell meter
Carl,
Old 04-06-2012, 03:25 PM
Hmmm, I have a timing light but it only flashes. I don't think it has any guage and I don't have a tach/dwell meter - but, I know someone who has one.
Thanks.
Old 04-06-2012, 04:16 PM
80-911SC's Avatar
Look around for a tach / dwell engine diagnostic .. they can be found on ebay for not to much ... also you could hook up another tach and check it vs yours .. easy if you have some one around with a Porsche and a compatible tach ... or if you could wire in an aftermarket tach in temporarily ...
Old 04-06-2012, 05:06 PM
Member 911 Anonymous
DRACO A5OG's Avatar
my LM2 has a Tach feature
There are some DVM that registers tachs as well.
'85 Carrera Targa
PCA/POC
Old 04-06-2012, 08:45 PM
cashman's Avatar
My DVM purchased from AZ plugs into the coil and gives you a digital reading.
1989 911 Carrera Cab
25th Anniversary Edition
Euro Pre-Muffler, SW Chip
There's nothing better than: Listening to "Going Down the Road Feeling Bad" ,as I, "Go Down the Road Feeling Bad"
Old 04-06-2012, 09:03 PM
dshepp806's Avatar
My meter gets it off of the coil, as well.
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 04-07-2012, 03:09 AM
