Need help on Fresh air blower unit
Hi,
I disassembled the fresh air blower in my 1970 911T to swap the broken blower motor. Once disassembled I gave the whole unit a thorough clean up and have all parts necessary to re-assemble - except for below sealing rings which literally fell apart upon touching them.
Can one of you help me out with a parts number for it (can't find it in the Porsche parts list) or a handy trick what material to use to 'build my own'?
Thanks for any hints...
C
This is where they sit:
This is what it looks like:
1970 911T
Old 04-09-2012, 02:59 AM
kuehl's Avatar
On the 2 round sealing doors, measure the thickness of the black foam material where it has not been compressed.
Go to McMaster Carr catalog, start page 3550 (in present catalog), look for a:
Closed cell
Weather resistant
Neoprene/EPDM/Foam,
Adhesive backed or you can glue with upholstery glue
Firmness (25% Deflection): 5-9 psi (soft)
McMaster-Carr
Old 04-09-2012, 04:56 AM
pete3799's Avatar
I've got some stuff that i used on mine.
It's foam on one side and has sort of a soft plastic coating on the other side.
If you want to PM me i'll send you a piece big enough to do them.
Pete
79 911SC RoW
Old 04-09-2012, 05:15 AM
