Oil Return lines on an 1980 SC
Hi,
Bought a ROW 1980 911 and it had aftermarket steel braided cables that connect it to the external oil cooler in the front wheel well.
Have taken it to a hose place and the cannot work out the fitting that comes form both the engine and oil reservoir.
Can anyone help with what sizes they are and where I can source the fittings.
thanks in advance
Geoff
Old 04-10-2012, 06:37 PM
Contact BoxsterGT.........
BoxsterGT (Len) has an assortment of metric fittings for 911 oil and fuel lines. He'll even fabricate custom made lines for your needs.
Tony
Old 04-10-2012, 07:48 PM
Canyon Runner
70SC's Avatar
Porsche Crest
Like these Hi Len
Old 04-10-2012, 08:15 PM
schumicat's Avatar
elephant racing and pegasus racing sell the fittings
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 04-11-2012, 02:46 AM
BoxsterGT's Avatar
Porsche Crest
The fittings for your 911SC Oil system have M30x1.5 threads. The pipe you show goes to the left hose in this photo............
I can re-hose the ones shown or you can buy new from our host. Not expensive either way. Typical cost to re-hose the one hose assy that connects to your engine pipe is about $35.
The female straight fitting itself that attaches to your pipe and also to the tank is $25.
Len at Autosportengineering dot com
Old 04-11-2012, 05:45 AM
BoxsterGT's Avatar
Porsche Crest
Geoff-
I sounds like you may have a "Terbatrol" oil cooler setup that used braided -12AN hoses up front & back.
If you post a photo of what you have we can likely identify and help you with this.
What is the problem, have the hoses started leaking?
Len
Old 04-11-2012, 09:01 AM
Hi Len,
I am trying to find a picture of them. I currently have the hoses with a hydraulic hose firm.
The reason I needed them changed was an oil leak which when I investigated found the hose couplings connecting to the thermostat to be severely erroded.
However this is related to a previous post I made called Check out the Oil Lines. In that post I did include photos (which I can no longer find - always the way )
In the short term I will use a good quality clamp to hold new rubber hoses. This is based on the recommendation of a porsche trained mechanic.
In the long term I will have to get the proper fittings.
thanks for the great help
I am so glad a site like this exists where there is invaluable help
Old 04-11-2012, 08:02 PM
ROW '78 911 Targa
timmy2's Avatar
This one?
Check out the oil lines
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 04-11-2012, 10:26 PM
BoxsterGT's Avatar
Porsche Crest
OK, this is the same issue discussed earlier.
For a temporary measure, throw away that aftermarket oil cooler crap & run a Factory hose from engine to tank w PN 911 107 742 10. Its for your model but without a front cooler, and only $70 from our host. It will eliminate all your leaking hose issues. If I can find a photo of this I will Post it.
You can then drive & enjoy your Porsche while you decide what you want to do for a front cooler if anything at all.
Len
Old 04-13-2012, 06:00 AM
BoxsterGT's Avatar
Porsche Crest
Geoff-
Here it is in the Pelican Parts catalog............ Only $70 from our host and it will do the job just fine.
Len
Old 04-13-2012, 06:20 AM
