Less brakes, more gas!
euro911sc's Avatar
Milky Brake Fluid?
I was flushing the brakes in prep for a DE weekend. I'm switching from Motul to RS683 so I wanted flush out the system. When I held up a light to the drain hose I could see what looked like some milky stuff flowing along with the brake fluid. Not a lot, but a consistent ribbon of something. I could not tell what color it was since the hose is grungy. No air bubbles, though. I went through a whole bottle of RS683 trying to get it all out. It really only made an appearance at the rears. What is it? Water? Oil? I am not sure I got it all out, but I tried. The Motul was about a year old.
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 04-13-2012, 07:38 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
Probably water. Flush the system out really well.
Old 04-13-2012, 07:43 AM
euro911sc's Avatar
That's what I am assuming it is, but prior to putting the Motul I was flushing the brake system 3-4 times/year for the previous 2 years... which means it must have collected in a year? Seems off especially since some cars don't change their fluids but once every 10-20 years... That Motul is not cheap either! Supposed to be a really good fluid so ...
I guess I'm saying I'm stumped as to where it would have come from... Old seals?
Michael
'13 Cayenne GTS
Old 04-13-2012, 11:14 AM
Florida
Old 04-13-2012, 11:31 AM
Tired Member
DaddyGlenn's Avatar
Originally Posted by jared at pelican parts View Post
florida
+1
Glenn
Daily Driver - '78 911SC RoW
Endurance Racer - '85.1 944
Street/Track Project - '86 951
Race Project - 944 Spec
Old 04-13-2012, 11:33 AM
brake fluid is very hydroscopic.. it will attract water from anyplace possible. I've never had a problem, but i change my fluid after every 2 DE's or after every Race weekend so i'm a bit retentive on that front. I would suggest that you use a motive pressure bleeder, push out all the old fluid with it (no new in it). Then run a bottle or 2 of the cheap stuff through the system with the motive again to just flush out any stuff, then blow clean again and then re-fill with what ever fluid you choose.
Old 04-13-2012, 11:57 AM
