Glowing Cat need advice
My Catalytic is glowing cherry red. I need some help with this. I was thinking clog
Your right
Check ignition advance.
Yep .. not good .. and not serviceable .. if your not in a smog state look at the bypass pipes .. if smog needed get out the check book and don't try the universal .. big headache ...
Headers and Megaphones.... ;)
or for the street: SSI HEs and B&B 2in 2out muffler (my setup, sounds amazing) |
Dumping gas?
Hi Andy, off the top of my head I would look for a used bypass pipe, remove the catalytic converter, and check the CIS system for proper functioning. If that works OK, not too rich, I would then put the catalytic converter back in and see what happens. If you still want it or need it for smog certification, that is. Also sometimes used ones are offered here that may still be good.
I have a CAT for sale if you need one.
From the sound of the exhaust, I think I do have a miss. I have new plugs, cap and rotor. I can also check and make sure the firing order is correct. I am going to check for spark at all the wires then go from there. In my area of the state, I just need to pass visual inspection so the cat doesn't need to be functional on the emissions system. If it is a clog, I am just going to break out the middle honey comb section.
IF the cat is glowing on an SC, it's clogged. You need to take care of it immediately. If no smog is required, just cut it open, remove the element inside (DONT touch it with bare hands) and weld the housing back together. Instant cat bypass.
When my cat glows, I turn a hose on it. Normally solves the problem. 'Course, it's hard to get the cat out of the neighbors tree post hosing...
You might be able to. I've always just cut and welded.
My welder is down right now.
can a clogged cat make it sound like it has a miss?
Uh, yeah. a big miss.
okay, i think I will tackle the clog first then before I check for a miss.
A long cheater bar, with a BFH will poke out the clogged pieces inside the cat....no need to cut it open in my experience.
It's a breaker bar, or crow bar in some counties. BIgEffinhammer
| All times are GMT -8. The time now is 08:33 AM. |
