Local Mad Scientist
Glowing Cat need advice
My Catalytic is glowing cherry red. I need some help with this. I was thinking clog
1982 Porsche 911sc 2009 Jeep Grand Cherokee Laredo X CPA-PCA Member Since 2012 |
Your right
83 SC |
Check ignition advance.
Yep .. not good .. and not serviceable .. if your not in a smog state look at the bypass pipes .. if smog needed get out the check book and don't try the universal .. big headache ...
Enthusiast
Headers and Megaphones....
![]() or for the street: SSI HEs and B&B 2in 2out muffler (my setup, sounds amazing)
Jonathon 1982 911 SC www.avrmotorsports.com |
Dumping gas?
Hi Andy, off the top of my head I would look for a used bypass pipe, remove the catalytic converter, and check the CIS system for proper functioning. If that works OK, not too rich, I would then put the catalytic converter back in and see what happens. If you still want it or need it for smog certification, that is. Also sometimes used ones are offered here that may still be good.
79 SC Targa 72 T Targa Sold 68 T Coupe Sold 65 912 Coupe Sold 62 356B Coupe Sold |
I have a CAT for sale if you need one.
james www.gruppe9autowerks.com Its not how fast you go...its how you go fast |
Local Mad Scientist
From the sound of the exhaust, I think I do have a miss. I have new plugs, cap and rotor. I can also check and make sure the firing order is correct. I am going to check for spark at all the wires then go from there. In my area of the state, I just need to pass visual inspection so the cat doesn't need to be functional on the emissions system. If it is a clog, I am just going to break out the middle honey comb section.
In the shop at Pelican
IF the cat is glowing on an SC, it's clogged. You need to take care of it immediately. If no smog is required, just cut it open, remove the element inside (DONT touch it with bare hands) and weld the housing back together. Instant cat bypass.
When my cat glows, I turn a hose on it. Normally solves the problem. 'Course, it's hard to get the cat out of the neighbors tree post hosing...
Local Mad Scientist
Thanks for the glove warning. Completely slipped my mind. Do you think it would be possible to break the inner part up with out cutting open and vacuum out the pieces.
You might be able to. I've always just cut and welded.
Local Mad Scientist
My welder is down right now.
Local Mad Scientist
can a clogged cat make it sound like it has a miss?
Uh, yeah. a big miss.
Local Mad Scientist
okay, i think I will tackle the clog first then before I check for a miss.
RETIRED
A long cheater bar, with a BFH will poke out the clogged pieces inside the cat....no need to cut it open in my experience.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
That is good information to have! Just a couple of dumm questions: What is a cheater bar, and what is a BFH?
80's Fan
It's a breaker bar, or crow bar in some counties. BIgEffinhammer
