911sc 3.0 Problem
noise, what could it be?
20120411_184433.mp4 - YouTube |
Are you talking about the clunking/rumble? Sorta like a thump thump with no real timing to it.
I'm sorry I do not understand the angielsku.Problem noise only occurs on cold engine
Take the fan belt off and try it for a very short while (no cooling)
ok thank you
That sounds like it could be your alternator bearing going. They make funny noises when they start to go and yet the alternator will still work. Take the belt off and rotate it by hand and see what kind of sound you get.
Also check for play in the shaft movement. SteveKJR |
| All times are GMT -8. The time now is 11:58 AM. |
