-   -   Procedure for checkng power to the CDI unit (http://forums.pelicanparts.com/porsche-911-technical-forum/671552-procedure-checkng-power-cdi-unit.html)
Sunroof 04-13-2012 08:35 PM
What is the proper procedure to check for power going into the 3-pin CDI unit? The CD unit is off the car and the three pin plug is exposed (red, green and black wires). I believe the red wire is the power wire to the CDI unit, but not positive. How would you check for proper voltage to this unit?
Bob
73.5T
HarryD 04-13-2012 09:23 PM
Hi Bob:
Always thrilled to help a fellow with a 1/2 year only car.
This thread may be helpful: http://forums.pelicanparts.com/porsche-911-technical-forum/364174-cdi-box-troubleshooting-help.html#post3448932.
You will find this in that thread:
Originally Posted by HarryD (Post 3448932)
You better check your wiring diagram. Per Permatune (http://www.perma-tune.com/T-ignition-Porsche-911.html):
A = + or 15, coil hot primary terminal ( - or 1, coil ground primary terminal is connected to the engine ground).
B = Power from ignition switch.
C = Distributor breaker points.
D = Ground
http://www.perma-tune.com/images/misc/911plug.jpg
