While the engine is out....:)
So fixing the oil leaks is about an hour's work. Cleaning up after said oil leaks takes forever. The following checkpoint photo is submitted for your review:
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 04-16-2012, 06:24 PM
looking good. what did you use?
Old 04-16-2012, 08:26 PM
French Import
zippy_gg's Avatar
New engine sound pad before reassembly?
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 04-16-2012, 08:40 PM
evil trinity, hoses, throttle bellcrank bushings (trans & engine), for sure valve lash, oil cooler seals, flywheel seal, crank seal, clutch, TO brg., pilot brg., press plate, clutch fork, clutch fork bush., 1st gear dog teeth, trans input shaft seal, shift shaft seal, head temp sender. I will stop now. This is basically what I have done when doing a clutch job, but I have had the engine out 3 times, yes 3 times. Use seals from our host or Porsche.
Old 04-17-2012, 05:54 AM
Original GUNK and a toothbrush. My garage smelled funny for a couple of weeks. But well worth it.
Old 04-17-2012, 06:05 AM
How did you know? I was going to clean up the old adhesive and wax it up. After ten minutes of working with the old adhesive a new sound pad was looking better and better. LOL.
Old 04-17-2012, 06:06 AM
