Location: behind the redwood curtain, (humboldt county) california
Brake pad choice
I've tried a few searches and come up with zip.
I have a very stock 74 used as a daily driver but want more out of the brakes. I've had pad fade on a very long down hill run and at that time, also a bit of pulsation in the pedal. I think my dad just ran the stock textar pads. Is there a preference for Pagid R4-s or EBC Yellow Stuff?? Are they comperable?? What are the trade offs. I will get more air to the fronts, eventually, but one caliper is sticking, so i thought i would rebuild both and install new pistons and pads. Mired in ignorance, once again, chris |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Brake pads.
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
I ran the Textar's and was quite happy on the street and even ran a bunch of DE's
I tend to overheat them now for DE so I switched to Padig Blacks but they SUCK for street use! (very very noisy) I suggest you look into your brake fluid too - I cant imagine brake fade on a steep hill...I run 30 minutes at 125 mph and hard braking without issues so if they still "fade" try new fluid also try down shifting and using a little of the motor to keep you slow - I drive down a long steep hill to work everyday and I dont even hit the brakes but one good slow right before the spot the cop likes to hang out....otherwise I just use a lower gear and let it roll just thoughts
Ed M 86' Coupe |
I have the Porterfield R4S pads and love them.
Thanks for the input guys. I will do the rebuild and give it a try again.
How would you copare the porterfield to the textar?? thanks, chris |
Rebuilding should fix your sticking caliper. You don't need new pistons unless the old ones are pitted. Pulsating brake pedals usually indicate warped rotors.
Doug 79 SC Targa w/ ITBs, 2004 Cayenne Turbo |
