vesnyder's Avatar
Send a message via AIM to vesnyder Send a message via Yahoo to vesnyder
New Exhaust Studs??
I am swapping out my OEM heat exchangers for a set do SSI's. Would you recommend changing the mountings studs and hardware? Some of the studs came out when I removed the original heat exchangers and was wondering if new studs and nuts would reduce the corrosion and make removal easier next time.
Vance
'83 SC Cabriolet - The "Matrix"
'73 914 - "Spicy Mustard" - SOLD
Old 04-18-2012, 07:16 PM
I am going through the same thing, sort of. I removed my heat exchangers but none of my studs came out. I do have one bent stud though. Several people have said to replace but 3 different long time Porsche mechanics said less is best with exhaust studs and to not mess with them, even though my engine is out of the car. Just one broken stud can be a real hassle.
Jonathan
Hwgunner
jonathan
hwgunner
Old 04-18-2012, 09:45 PM
Spiderman
Jesse16's Avatar
I'd recommend if they aren't damaged after removing your exhaust, just clean em and leave em. Use anti-sieze at assy. I replaced mine and think it was a useless effort and expense. You don't or should not torque them much and the heat while not low isn't extreme for steel anyway. My exhaust system came off pretty easy after a few days of penetrant and using the "tighten till you hear/feel a ping", then loosen the nut technique. All the nuts came off easy.
Midnight Blue 08 Cayman S, Fun/Track
Black 12 VW-GTI, work
Mexico Blue 87 Carrera, sold, sad, not enough garage space.
Old 04-19-2012, 06:04 AM
trak ratt's Avatar
I'd replace all that came out and try to remove the others. They're prolly old, with lots of heat cycles. Studs aren't very expensive and why would you want to reuse old fasteners for a new exhaust system.
Old 04-19-2012, 07:35 AM
porsher
aston@ultrasw.c's Avatar
Replacing the studs is a great idea right up to the point where you break one backing it out.
Leave 'em
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
Old 04-19-2012, 07:48 AM
Mo money = mo parts
Leave 'em
+1 If they didn't snap in the process of removing the heat exchanger and the threads are decent enough to rethread, I would agree - leave them. I had one snap off even with the head when I tried removing the nut and even though I had a special stud drilling guide I needed to install a timesert. As Aston suggested, you won't be happy if your project gets a lot bigger for no real benefit. Just coat the studs with anti-seize.
Greg
86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten
65 Ducati Monza 250 & 66 Monza Junior (project)
"if you are lucky enough to own a Porsche, you are lucky enough"
Old 04-19-2012, 10:47 AM
I also agree to leave them. Sure its a good idea to do it, but not if you are going to break one.
If you leave them, they will last for many years to come, by which time it will not be a concern of yours anyway. And if they break at some point in the future, they were gonna break when you tried to extract them anyway.
I would probably take the step of reassembling with new nuts though and lots of anti-seize. Will at least give the next owner of the car a fighting chance.
Old 04-19-2012, 11:15 AM
KTL KTL is online now
Schleprock
KTL's Avatar
If you have some studs that came out when you removed the nuts, you probably weren't using heat to remove them. Which means you got VERY lucky that you didn't break any. I too got lucky like that when I first bought my '87 twelve years ago.
Do yourself a favor and put three new ones in there and LEAVE THE REST ALONE. You're "playing with house money" right now, so quit while you're ahead!
Kevin L
'86 Carrera "Larry"
Old 04-19-2012, 12:52 PM
Banned
These are easy questions to answer - new nuts = yes . . . new studs = HELL NO (for the reason(s) others have given)!
Old 04-19-2012, 01:02 PM
grateful user
don gilbert's Avatar
I got tired of leaks because I was afraid of going to tight on the old crusty studs after the SSi swap. Finally broke a few and decided to fix it for good when i pulled the engine for something else. Drilled the holes out to 10 mm and used allens, can tighten the heck out of them, and no leaks since. Be sure and get the 74 down gasket, lots thicker than the thin copper for 75 up.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 04-19-2012, 03:14 PM
a.k.a. G-man
Geronimo '74's Avatar
If your engine is out of the car, replace them.
Use lots of heat and be careful
Some will/might snap and that sucks but it's not like the world will come to and end...
Heat cycling makes them brittle.
SSI's thick or thin flange? Thick, and you may need longer studs anyway...
Replace and be done with it, I say.
Old 04-20-2012, 02:37 AM
